t34 57 exhaust housing
well i was told there was only 4 ever made....he used it for two stages so is like new.......has 2 stamped on the shaft but has been balanced where 4 and 7 would be ..........roller bearing,fully lockwired,cut back blades and msa tagged 34 mm restrictor.........thanks lads
think so..........
you might belive the bloke was pulling my leg, but i saw the car and all the parts he owed a main dealers.....
wish i had more money back then........
well its going on my engine..... just got to find time to put my car back together........hope to be out on the road again soon, should turn some heads and scarey as fook ..........
im almost sure it is, i used to run a hybrid on my rally car, was the ST escort rear and core with the Nissan sunny GTiR comp housing and wheel (same size as the escort T34) was an awsome turbo, just kept shitting itself at 2 bar, the thrust bearing was just too small for that much boost.
Russ Payne
25-09-2015 08:29 PM
