No Boost?! Well i had some, and now i don't again.
Old 07-12-2004 | 10:22 PM
Hofajoab's Avatar
Hofajoab
Default No Boost?! Well i had some, and now i don't again.
As you know i got my turbo in the car but no boost
no smoke from turbo, definitely getting oil and draining oil. No intercooler on it at the moment as i havn't got the piping for it ..
Id idles abover 1k though which is a bit high. It also doesn't boost at all but if i rev it to over 4.5k and change gear i can hear the turbo.
Any ideas?
Old 07-12-2004 | 10:29 PM
Ginge !'s Avatar
Ginge !
just finding my feet
get the system presure tested
mines got no boost at the moment as the boost pipe keeps poping off ( fooking wankey taxi bit of shit )
Old 07-12-2004 | 10:34 PM
Hofajoab's Avatar
Hofajoab
woudl the slightest leak on the exhaust manifold to turbo make that much of a difference as i havn't got a gasket for it yet?
wankey taxi lol, ah well i'd be lucky if a boost pipe flew off
Old 07-12-2004 | 10:37 PM
Exeter J's Avatar
Exeter J
You don't think the wastegate is stuck open ?
Old 07-12-2004 | 10:39 PM
Hofajoab's Avatar
Hofajoab
it's a possibility...
i can move the actuator rod by hand and let it spring back in and i can hear something close (i.e. have contact with metal) so i'm guessing it isn't stuck open?! ... but.. should it be possible to to move the rod by hand or is it goosed?
Old 07-12-2004 | 10:42 PM
DOO's Avatar
DOO
you need a new actutor then if it moves that easy
Old 07-12-2004 | 10:43 PM
Jasesapphy's Avatar
Jasesapphy
You dont need a gasket for the turbo to manifold.
Check how long the actuator arm is or is it attached,
Are the hoses all connected , you havent got a split in one have you..
I had that overtaking boost guage showing 10psi then nothing, fuck all
Hofajoab's Avatar
Hofajoab
i take that means that the actuator will move at minimal boost and open the wastegate?
Old 07-12-2004 | 10:46 PM
Hofajoab's Avatar
Hofajoab
don't think i have any leaks in any hoses but i'll give them a check.. it probably is the actuator though as i tried moving my friends by hand but couldn't!
Old 07-12-2004 | 10:55 PM
DOO's Avatar
DOO
if you can move the act without effort by hand mate it fooked won`t give you any boost or hold any.cost around £70 stu sales them on here MSD
Old 07-12-2004 | 10:56 PM
Hofajoab's Avatar
Hofajoab
it takes a little effort but i can move it by hand
Old 07-12-2004 | 10:58 PM
Exeter J's Avatar
Exeter J
Yep - as you say even a standard sprung actuator is pretty hard to pull out by hand. If the spring has gone soft then it will open a much lower boost and dump your boost pressure down the wastegate.
Old 07-12-2004 | 11:00 PM
Exeter J's Avatar
Exeter J
Ah - you can move them by hand but it should need a firm grip rather than say pulled with your fingers. Difficult to discribe i suppose.
Old 07-12-2004 | 11:02 PM
Hofajoab's Avatar
Hofajoab
erm well it doesn't just move, i do need to apply a fair amount of pressure but can still do it with my hand without tooooooo much of a difficulty!
hmm
Old 07-12-2004 | 11:08 PM
Exeter J's Avatar
Exeter J
Is that 'tooo' much or 'tooooooooooooooooo' much ??
Possibly sounds like it should be strong enough to allow some level of boost to form.
Have you got a boost gauge plumbed up? - Does it read anything at all ?
Old 07-12-2004 | 11:14 PM
Hofajoab's Avatar
Hofajoab
no boost guage as of yet (i really need one )
I can't feel any extra pull though so i doubt if it's boosting at all! Would it be advisable to screw the rod right in and see if it starts boosting a bit or would i be asking for trouble
Old 08-12-2004 | 08:31 AM
Jim Galbally's Avatar
Jim Galbally
cant hurt to try it i s'pose...
slight leak on manifold shouldnt cause no boost... big leak will
can you hear the turbo spinning up and a constant hissing noise?
what actuator do you have, standard one?
also i asusme its piped in straight off the compressor housing?
if so you should see about 3psi with the correct preload... even less with the actuator a bit worn or set incorrectly... lol
go out and buy a boost gauge asap... even a tim one! lol
if you unclip the actuator rod from the wastegate penny the hole in the rod should cover HALF of the thing it clips into (hard to explain but its obvious when you look at it) if yours is too long... itll boost very low... too short and itll boost too much...
it should be set to cover half (hence the term half hole preload )
also you'll want a bleed valve on there if youre using a standard actuator... as you wont be able to hit more than about 4psi without one... lol
Old 08-12-2004 | 09:30 AM
rabmc's Avatar
rabmc
i struggle to move my actuator it should be really tight/strong turbo in the sierra should i be watching my back m8 oh and buy a bleed valve that should help determine boost a bit easier if u no what i mean
Old 08-12-2004 | 09:35 AM
Hofajoab's Avatar
Hofajoab
well sounds like a new actuator it is! meh, always sommit!
I'll need to get a boost guage asap as you said jim, i've got a schematic to make up a Air/Fuel meter so i'll get that going tomorrow i should think.
I'll see if i can get some boost first before i get the bleed valve, i'd be happy with 4psi
Rab - I don't think you'll need to watch your back lol, unless my brakes don't work
Ah i'll get it sorted over the weekend hopefully, cheers!
Old 08-12-2004 | 09:41 AM
rabmc's Avatar
rabmc
what size of turbo u running
Old 08-12-2004 | 09:42 AM
Hofajoab's Avatar
Hofajoab
it's a T25, and i'll only be running about 5-7psi at the moment.
Old 08-12-2004 | 09:44 AM
rabmc's Avatar
rabmc
standard compression / pistons ? how much boost can those babys take
Old 08-12-2004 | 09:46 AM
Hofajoab's Avatar
Hofajoab
yup standard compression. I think someone is running about 9psi lol, but he has a big intercooler, oil cooler etc and probably a good bit of tuning.
Anymore than that and i can see it melting/breaking a few things
Old 08-12-2004 | 09:52 AM
Jim Galbally
just make sure you check that preload before you go out and buy another one...
youll be a bit gutted if you buy one and theres nothing wrong with the std one... lol
i wouldnt expect you to notice much of a performance difference with 2-3psi so it MAY be boosting and you just dont notice it... lol
have you got a dumpvalve fitted? does it go tish? lol
Old 08-12-2004 | 09:53 AM
Jim Galbally
ps on my old 4x4 TTs even with the wastegates unhooked i could still get 1-2psi at the top end of the rev range on full throttle
Old 08-12-2004 | 09:56 AM
Hofajoab's Avatar
Hofajoab
lmao Jim, nah i don't have a dumpvalve fitted, urgh!
Like you say at the top of the rev range on full throttle it must be boosting a little bit as i can hear the turbo making a noise when i change gear. when i say noise, it's not a chatter, just a kind of whine?!
I'll check the preload today mate, just going out in 10 mins to set about it!
Old 08-12-2004 | 10:00 AM
Jim Galbally
oh and if you dont have a bleed valve, just use a T peice on the line from turbo to actuator... and let the T peice vent to air...
that should give you about 7-8psi i'd have thought...
dont leave it like this tho, just incase its running lean/detting
Old 08-12-2004 | 06:43 PM
Neil's Avatar
Neil
hofajoab
get it set up right on the preload, you want to run only about 4psi with no intercooler otherwise it is piston melt down
i have had the standard engine at 13 psi for about 5 minutes but clutch was stinking as couldn't cope with it
if u want a helping hand getting it set up right, i know a few good tricks on the standard ecu that makes it run even better when turbo as mines is done this way
neil
Old 08-12-2004 | 07:03 PM
Jasesapphy's Avatar
Jasesapphy
I run 10 psi without a bleed valve
Old 08-12-2004 | 07:07 PM
Jasesapphy's Avatar
Jasesapphy
Jim it would boost to about 11psi with a t piece open to air which would melt a piston with no intercooler
Old 08-12-2004 | 08:27 PM
Jim Galbally
jase, depends on actuator and actuator preload used...
and if you're hitting 11psi without a bleed valve then i'm 90% sure you're using a -31 actuator on yours
dont think you could get a std actuator to hit that even if you wound it RIGHT in
Old 08-12-2004 | 08:30 PM
Jasesapphy's Avatar
Jasesapphy
Standard actuator from turbo technics my old jimbo.
I run 10 psi, apparently the limit is 11psi on that actuator .
IV BEEN PLAYING
Old 08-12-2004 | 08:44 PM
Jim Galbally
you know you shouldnt give an actuator too much preload don't you?
-31s and -34s exist for a good reason, and it's not to rip people of... lol
Old 08-12-2004 | 08:56 PM
Jasesapphy's Avatar
Jasesapphy
Cheers Jimbo
Old 09-12-2004 | 12:48 PM
Hofajoab's Avatar
Hofajoab
right well i havn't had any spare to time to tinker with it yet but i quickly pulled off the vacuum/pressure feed to the actuator and it appears to be boosting as i can fell it, and i can hear the turbo do it's feeble whining when i change gear at about 3k or so (don't want to damage me engine ) ... so i presume that it MUST be the actuator?
I've tried adjusting the actuator rod in a good bit but that didn't work, only works when i disconnect the pressure feed.
Can these actuators be repaired, or once they're gone they're gone?! It'd cost me more for a new actuator than it did for the whole setup!
Old 09-12-2004 | 01:18 PM
Jim Galbally
theyre not user-serviceable
Old 09-12-2004 | 01:23 PM
Hofajoab's Avatar
Hofajoab
no probs, see if i can find a decent one in the scrappy if not i'm sure i'll find a second-hand one somewhere fook buying a new one pikey me
Old 09-12-2004 | 01:40 PM
JamboRS's Avatar
JamboRS
focus rs 1672
get one new m8,you'll be very lucky to find one in a scrappy,even if you do it will prob be as bad as yours.
there only about £80 quid anyway and if gets your car goin best £80 you'll ever spend
Old 09-12-2004 | 01:45 PM
Jim Galbally
or just get a -31 as you'll be running >7psi anyway and saves feckin about with bleed valves and other forms of boost control
Old 09-12-2004 | 02:01 PM
Hofajoab's Avatar
Hofajoab
yup, currently asking about for one mate, but the last thing i wanna do is spend £70 - £80 on the car just now, but if i have to i have to, i'm just tight lol.
Quick Reply: No Boost?! Well i had some, and now i don't again.
