Engine experts - Running a YB engine backwards
Old May 12, 2009 | 11:23 AM
ECU Monitor Enthusiast
Default Engine experts - Running a YB engine backwards
A little project for a YB transplant has interested me in which so many problems with transmission and installation etc.. could be solved if the engine ran in the opposite direction.
Apart form engine managment issues which I am fairly well up to speed on..LOL, what else would I need to change around to make this work.
Is it just a case of swapping the cams with each other and reversing the rods ????
Has anyone done this ?
Thanks in advance.
Old May 12, 2009 | 11:25 AM
joffy's Avatar
joffy
SLOW LEARNER
not an expert but exhaust and inlet manifolds bolting up differently??
Twellsie's Avatar
Twellsie
would this not make your forward gears run in reverse?
Old May 12, 2009 | 11:27 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
What do you mean by "run backwards" ?
Do you mean swap the inlet for the exhaust, like on a touring car Vauxhall Cavalier XE engine but the engine rotates the same direction still, or do you mean the engine physically rotating in the opposite direction?
(ie like a ITR DC2 honda engine)
The two are very different animals, I can give you some pretty good pointers on either, but cant be bothered to type out for both when one wont be needed so please be a bit clearer about what you want to do.
Old May 12, 2009 | 11:29 AM
joffy's Avatar
joffy
SLOW LEARNER
exhaust and inlet valves are different aswell?? sorry to go off track but if you could do it, could you in theory build a left hand drive cossie that was a complete mirror image of a left hand drive??
Old May 12, 2009 | 11:31 AM
No, they stay in the same place
Thats the idea
(I know this is an issue but I am not worried about this at this point in time)
Chip,
Keeping the engine layout the same..Just making it run the opposite direction.
MAybe but thats not what I want !
Old May 12, 2009 | 11:32 AM
foreigneRS's Avatar
foreigneRS
Testing the future
your starter motor would need to be reversed for a start
joffy's Avatar
joffy
SLOW LEARNER
now i understand, ignore all previous replies
Old May 12, 2009 | 11:39 AM
Chip's Avatar
Chip
Right, well to just run it backwards, the main things off the top of my head that are going to be an issue are:
Cambelt tensioner layout, the slack would be on the wrong side of the belt, so this will need changing
Starter motor, this will need changing internally to make it spin in the opposite direction
Cams, interesting one, given that all the YB profiles appear to me to be symmetrical im not convinced they would actually need changing other than the timing of them, not really looked into this enough to decide yet though, would need to just sit there and wind one over backwards and see what happens but I reckon it would just be a case of timing them differently.
Rods, the offset gudeon pin will be leaning the pistons the wrong way around, so rotate the piston and rod assembly the other way as the thrust side is now the opposite side.
You then potentially have the problem of the valve cutouts being the wrong way around, so you would need to check clearance of course.
Ive often thought about doing similar with a vauxhall engine (it would be the easiest way to 4wd my nova if I did so so) and thats the main things that Ive thought of so far that I would need to change to do so.
Old May 12, 2009 | 12:04 PM
.Ross.'s Avatar
.Ross.
Just forget about it mate ... Would be a Nite-mare from start to finish.
Only engine's that can run the other way pretty easy are 2-stoker's.
Old May 12, 2009 | 12:05 PM
Chip's Avatar
Chip
That much I reckon we all agree on, lol
Would make far more sense to just use a honda engine instead if he needs one that rotates the other way around!
Old May 12, 2009 | 12:08 PM
Daveyboy's Avatar
Daveyboy
why would you need the engine to rotate the other way?
Old May 12, 2009 | 12:12 PM
Twellsie's Avatar
Twellsie
i always presumed, that when you look at the engine, inlet on the right, exhaust on the left, the engine would rotate anti-clockwise and vice-versa
i presume this is not correct?
coleman's Avatar
coleman
Always in the background
+1
i'm confused.com!
Old May 12, 2009 | 12:20 PM
dojj's Avatar
dojj
Resident Wrestling Legend
oilways and thrust angles and all sorts would be issues first and foremost
nothing wrong with running the engien the other way around once they are done
Old May 12, 2009 | 12:25 PM
Chip's Avatar
Chip
Not correct at all mate, zetec engines and YB engines both rotate the same way, and yet have the inlet and exhaust the other way around.
Some older engines like renault 5 turbos and minis have both manifolds on one side of the head too.
Old May 12, 2009 | 12:27 PM
Chip's Avatar
Chip
Oil pump is another major one too mate, it would be trying to suck the oil out of the galleries and put it back into the pump, likewise the water pump
Thats true of all the ancilirries of course, so the alternator too, and probably even the power steering if its still attached.
But I was assuming all of those external things he would deal with seperately anyway, as obivously pumps can be swapped to electric etc.
Old May 12, 2009 | 12:32 PM
yappstar's Avatar
yappstar
Slightly off topic, but are electric oil pumps available? And are they reliable etc?
*On topic mode* Simon, go on spill the beans, why do you want to do this? Is it a purely theoretical thing or a technical exercise?
Old May 12, 2009 | 12:33 PM
Twellsie's Avatar
Twellsie
cheers Chip, always wondered that
Old May 12, 2009 | 12:35 PM
.Ross.'s Avatar
.Ross.
Would the head not work as it ... Keep the cam's spinning the right way and timed it right?
Old May 12, 2009 | 12:36 PM
Chip's Avatar
Chip
Yes they are, but I have never used one so cant comment on how well they work.
I would personally try and fit a pump designed to spin that way, and just accept that means a bit of machining rather than go electric myself, but then im a bit of a old fart and done even like to trust eletric water pumps
Chip's Avatar
Chip
Would the head not work as it ... Spinning the cam's the other way As long as you timed it right ..
Yes I beleive it would, as per my earlier reply saying exactly that.
Old May 12, 2009 | 12:38 PM
yappstar's Avatar
yappstar
Cool, never knew that, cheers
And I would be of the same opinion as you
.Ross.'s Avatar
.Ross.
Changed my post .. didnt sound right off the top of my head ..
Could the cam's run the other way from the crank? Need an Idler somewhere above the cam's or below the crank?
Old May 12, 2009 | 01:45 PM
dojj's Avatar
dojj
the idler could be sorted just by running a longer belt and using some maths
the dizzy is sorted as it can run coil pack
as you've sugested, turning the pistons around will sort the running out
oil pump can be electric (or dry sump it)
even the timing issues could be sorted just by having the cps repositioned or electronicly fiddled with
and if there is no dizzy and no oil pump, there is a big puley in the way to use as a make shift tensioner
Old May 12, 2009 | 02:28 PM
.Ross.'s Avatar
.Ross.
You would have to drive off the top of the crank pulley or from the bottom of the cam pulleys .. Cannot think of a way to re-route the belt?
Old May 12, 2009 | 03:10 PM
Some interesting reading !
This is for the possibility of doing a mid engine conversion with the engine in a "south-north" configuration.
Dont want to say too much just yet as it isnt my car.
The only other thing I can think of here is the oil surge to the front of the engine under hard acceleration !
Old May 12, 2009 | 03:12 PM
dojj's Avatar
dojj
but with no oil pump or dizzy there is another pully you can use as the tensioner
but it would need the teeth ground off of it to make it viable
Old May 12, 2009 | 03:29 PM
.Ross.'s Avatar
.Ross.
Yeah ... But how would you make the cam's turn the opposite of the Crank? Have to run a pulley above or below .. Cannot cross the belt.
Old May 12, 2009 | 03:49 PM
Dark-Horse,
The cams would rotate backwards too.
I think swapping the cams over and retiming them "may" sort the issue as long as the lift for each shaft is acceptable.
Maybe...LOL
Old May 12, 2009 | 03:54 PM
rs2klee's Avatar
rs2klee
K***LMT
to run it the wrong way.. all the bolts would come loose and fall off.. you would have to thread parts all the other way also!
Old May 12, 2009 | 03:57 PM
Chip's Avatar
Chip
Originally Posted by Flux Capacitor.
Dark-Horse,
Maybe...LOL
Why would you swap them over?
The inlet would still be the inlet, and the exhaust would still be the exhaust, so why swap them?
Old May 12, 2009 | 04:01 PM
Chip,
To maintain the proper firing order.
I think from memory, the valve sequence is reverse on the cams if you compare them otherwise 2 standard cams would be interchangable.
I may be wrong as I havent any to hand to look at them !
Hope you see what I am getting at !
Old May 12, 2009 | 04:38 PM
Chip's Avatar
Chip
Chip,
Both cams are in the same order 1-3-4-2
So swapping the exhuast cam for the inlet cam wont make any difference to that order.
And now would you want to as far as I can see.
Whats your reason for doing this, cause the amount of engineering involved is going to be very prohibitive cost wise?
Why not just use a honda engine that rotates that way anyway?
Old May 12, 2009 | 07:10 PM
PAUL S's Avatar
PAUL S
There is a much easier way to achieve what you want, which I assume is a YB rear mounted with the 4x4 box facing forward so that the front diff in its normal location drives the rear wheels and the rear diff drives the front -you just flip both the front and rear diffs over by 180 degrees to achieve forward motion through the entire gear range
Old May 12, 2009 | 07:14 PM
PAUL S's Avatar
PAUL S
do you want to instal the cosworth 4x4 drivetrain as it is but as per the 6r4 below
Old May 12, 2009 | 07:15 PM
PAUL S's Avatar
PAUL S
Old May 12, 2009 | 07:39 PM
bbspolo's Avatar
bbspolo
if u just fliped the diffs 180 then wouldnt u have most of the drive 2 the front wheels (being the rear diff?)
Old May 12, 2009 | 07:57 PM
J1mbo's Avatar
J1mbo
B1mbo
the diff is not what controls how much % of drive each diff gets, its the unit in the back of the gearbox that controls how much the front and rear diffs get
eg. 50/50 %split
25/65 %split
is this what you mean ?
Old May 12, 2009 | 08:13 PM
Twellsie's Avatar
Twellsie
eg. 50/50 %split
25/65 %split
percentages not your strong point Jimbo?
