Engine experts - Running a YB engine backwards
Old May 12, 2009 | 08:18 PM
  #41
89xr2's Avatar
89xr2
Brap!
Chip, do you know the reasons behind the honda engine running the other way round?
Old May 12, 2009 | 08:19 PM
  #42
doctor stavros's Avatar
doctor stavros
AMG C32
Originally Posted by Twellsie
percentages not your strong point Jimbo?
Old May 12, 2009 | 08:30 PM
  #43
PAUL S's Avatar
PAUL S
Originally Posted by J1mbo
the diff is not what controls how much % of drive each diff gets, its the unit in the back of the gearbox that controls how much the front and rear diffs get
eg. 50/50 %split
25/65 %split
is this what you mean ?
as Jimbo said you would also need to change the gearing in the transfer box if you did not want more power going to the front diff in the layout I mention, but 50/50 splits are available for the MT75.
I doubt a normal 4x4 front diff would be suitable to power the rear wheels but it would be straight forward to use a bigger diff as you would not have the normal restriction of the RHD rack being in the way, or you could put it to the rear of the engine rather than though the sump if you did use this configeration
Old May 12, 2009 | 08:38 PM
  #44
cossie604's Avatar
cossie604
Originally Posted by dojj
the idler could be sorted just by running a longer belt and using some maths
Its hardly maths is it Dojj...just measure the length required and buy it
Old May 12, 2009 | 08:39 PM
  #45
dojj's Avatar
dojj
Resident Wrestling Legend
the centre diff put a 1/3 2/3 split due to one bit rotating twice as fast as the other which is then reduced again to ge tthe right ratio to get the props front and rear
easy enough to just weld it up to be a solid bit of kit to give you no slip if it's a case of just powering it up
but that still leaves you with a more fwd 4wd car
Old May 12, 2009 | 08:40 PM
  #46
dojj's Avatar
dojj
lke jimbo, numbers aren't my strong point (unless he's removed 10% due to transmission losses before anyone starts dissing his figures )
Old May 12, 2009 | 08:43 PM
  #47
J1mbo's Avatar
J1mbo
B1mbo
afpmsl
sorry i did mean 75
Old May 12, 2009 | 08:45 PM
  #48
ECU Monitor Enthusiast
Jimbo,
LOL, we both have problems with the same numbers.... "FREE"
Old May 12, 2009 | 09:03 PM
  #49
J1mbo's Avatar
J1mbo
B1mbo
Originally Posted by Flux Capacitor.
Jimbo,
dont get me started
Old May 12, 2009 | 09:05 PM
  #50
bbspolo's Avatar
bbspolo
i know the diffs doesnt control how much power goes were but dint know you could get 50/50 splits for the mt75?
good point about positioning the front (now the rear diff) in front of the sump instead of though the sump!
id be tempted 2 use 2 jag diffs like that that rod runs, loads of different ratios avabiale, cheep (just weigh a bit more)
only weak point would be the gbox?
Old May 12, 2009 | 09:13 PM
  #51
steveboyslim's Avatar
steveboyslim
Default Reversing The Drive
Why not use a pair of drop gears to reverse the direction as they did on the RS200.
Steve
PS Honda said it help with traction having the engine/prop/diff rotate the other direction.
Old May 12, 2009 | 09:16 PM
  #52
Twellsie's Avatar
Twellsie
cant the torque split between front and rear be altered by using differant viscosity fluids, or something along those lines?
Old May 12, 2009 | 09:38 PM
  #53
GARETH T's Avatar
GARETH T
i personally would plan another way around your problem!
Old May 12, 2009 | 09:43 PM
  #54
blacky.'s Avatar
blacky.
why not just turn the final drive 180 deg then there is no need to reverse the motor???????????????????
Old May 12, 2009 | 10:00 PM
  #55
Fudgey's Avatar
Fudgey
Baby Cheesus
simon, speak to quaife.
they built a rear engined race car, using a cossie motor and 4x4 running gear in reverse, hell they even still have the car, so just buy it off them lol
Old May 12, 2009 | 10:06 PM
  #56
dojj's Avatar
dojj
no mate, it's due to one bit spinning twice the speed (the front) so getting half the torque (1/3rd is half of 2/3rd's )
Old May 12, 2009 | 10:15 PM
  #57
Chip's Avatar
Chip
*** Sierra RS Custard ***
So that the torque reaction tips the engine the other way, to aid with traction is the usually accepted story you see thrown about, dont know if its true or not though.
Old May 13, 2009 | 08:56 AM
  #58
foreigneRS's Avatar
foreigneRS
Testing the future
they do say that, and on race bikes too (not just honda)
Old May 13, 2009 | 12:17 PM
  #59
Rs1's Avatar
Rs1
Think its been said but cant you just turn the diffs upside down?
Old May 17, 2009 | 11:47 AM
  #60
evo200's Avatar
evo200
Originally Posted by PAUL S
do you want to instal the cosworth 4x4 drivetrain as it is but as per the 6r4 below
I looked into doing this with my RS200 rep. Had it all worked out too, but the killer for the project was the fact that to get two narrow bucket seats in the car meant the engine + box needed to be offset to keep the transmission tunnel in the centre of the chassis. That also meant taht the driving position was too offset for the pedals + steering wheel. Either that or have the g/box in the centre of the car and the Transfer box intruding into the passenger side and have no passenger seat!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Red_bull
Aug 25, 2015 06:27 PM
