General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hasnt he already built loads of focus mk2 based 4x4 cars???
Originally Posted by MadMac
Thats what haldex was for.
Isnt the fundamental flaw with haldex ford would have used, the fact that it is based on sending 95% of the power to the front wheels most of the time, then sending more power to the rears only when traction is lost up front???
where as in an ideal 4wd car dont you want a different split so that for better handling you dont need to loose traction before you get the 4wd handling benefits????
With haldex i cant see the point of the extra wieght if you are already loosing speed and grip (and adding time to your lap time on track) before you get the 4wd benefits.
Hence why the testing showed the focus RS better with FWD as you could easily design the car to run like that rather than having to change the handling characteristics to fit the rapidly changing front/rear torque split on the boundary of losing control!! A permenant 4wd system might have worked as you would set up handling/track etc to suit the 4wd system. Shame ford doesnt have that kind of money.
