Actuators
Old May 14, 2009 | 09:31 PM
  #41
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by Stu @ M Developments
If Will wasnt happy with your makeshift bracket then id replace it if you can mate. I dont recall the precise issue with i so cant elaborate sadly.
Will wasn't happy with the WOT % the TPS was reading.
I can change the bracket. I was not aware it made such a difference to the TPS readings, which i am not able to check
Steve
Old May 14, 2009 | 09:46 PM
  #42
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Steve, as i remember, the issue with the bracket was the distance it sat the throttle cable away from the throttle body.
From memory i seem to recall that on the original holes after fitting and calibrating your new TPS the maximum readings we could achieve were approximately 60-65%.
After grinding the mounting holes as much as i dared we were into the 75% region which is right on the tolerance for Wide Open Throttle conditions.
I seem to recall i stopped at that point for fear of weakening the bracket structure to the point that there would have been a risk of failure.
If you want to fit your new bracket before the car comes back up to us, i'll be checking the calibration and sensor range as part of the pre-mapping check so can make any adjustments at that point.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
