The difference between 2wd and 4wd cossie boost hoses??
As title really,wats the difference between the boost hoses on a 2wd and 4wd cossie??longer,shorter,bigger,smaller,different bore size??
Cheers.
Cheers.
Testing the future
bore size same.
when i fitted 4x4 i/c to my 2wd, i had to shorten the i/c to throttle body hose, and the compressor to i/c hose goes at a funny angle. this is due to the increased core depth of the 4x4 i/c.
Testing the future
i assume so, but don't know for sure as i haven't tried.
what you also have to consider is not only the difference in i/c size that changes the inlet and outlet positions, but due to different manifold, the 4x4 turbo is maybe in a different place, and the 4x4 inlet plenum is different.
The reason i ask is because i've got a bit of a mix and match set up of 4x4 intercooler,4x4 exhaust manifold and turbo and 2wd inlet manifold.
Thats what i was thinking,4x4 ones.
Cheers for the replys.
09-10-2015 07:38 PM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
