Putting a zetec lump in an xr2
how easy is this to do i mean is there alot of made up things 4 it like adapter plates and things or will i have to get things made up myself and cut and chop wires about and stuff or will it be quite easy to do?
Yo Dan!
Depends which zetec your putting in. I know that the black top 2.0 zetec needs some sort of adapter plate fabricating to allow the efi manifold to bolt in place, I'm not not sure if this is the case with the silver top 2.0 though. The 1.8 will fit in very easily requiring very little to get it running, in fact it might just be a case of switching the ecu and engine loom over, oh and the block of course.
I know on the mk2 and I'm sure it's the same on the mk3 if you fit the 2.0 you have to change the sump to the 1.6 or 1.8 item to allow the downpipe to exit in the correct position. You may also need the cvh oil filter.
JoeyBoyden
04-01-2024 02:36 PM
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
