do low comp pistons rattle?
Fucked On Race Day!!
Have 7.5:1 low comp accralite pistons and sounds like i have piston slap that doesn't go away. Had it checked and they fit perfectly in the bore, and have been told by different people that this is typical short skirt pistons...is this right?
its not about the comp its how the block has been machined to take the pistons...
The tolerance etc etc. Thats how i beleive it anyway
Piston slap is caused by wear to the bore over time. therefore if the bore is not machined to the correct tolelerances of the piston it will slap from the beginning.
people that do home builds and just hand it all to the machine shop without giving tried and tested diameters etc etc generally experience piston slap more...
Im sure people will come and shoot me down but im always trying to learn so dont abuse me too much lol.
What piston to bore clearance do you have? There should be no noise when its warmed up, I run lots of pistons with central pins and they are not noisy.
My mate had Arias pistons with Eagle rods in his Pulsar GTiR and they rattled from cold, sounded a little bit like a diesel does, but once the engine warmed up they quietened down.
It Wasnt Me!
deathrider666
28-09-2015 06:12 PM
