Best way to saturate wood with water?
Old Apr 30, 2009 | 06:09 PM
Stu.H's Avatar
Stu.H
Default Best way to saturate wood with water?
Ive got some kiln dried wood that I will be using in my fish tank, but want it saturated so it sinks.
Its been in a big tank (weighted down to the bottom) for a few weeks now, and although the buoyancy has reduced loads, it still does float slowly.
I had it in my tank before and had a big rock on it. Does warmer water aid in penetrating the wood?
Any ideas would be good!
Old Apr 30, 2009 | 06:11 PM
G950KDT's Avatar
G950KDT
possibly with warmer water it may work mate, but worth a shot!
yappstar's Avatar
yappstar
I dont know if you can do it so it will sink.
could you try filling one side with nails/screws to weight it?
Old Apr 30, 2009 | 06:20 PM
Stu.H's Avatar
Stu.H
It does work as had it in a tank before.
Could weight it but dont really want foreign objects in the water and dont want to adhere it to slate if I can help it.
Thanks for replies!
Old Apr 30, 2009 | 06:21 PM
Kris_23's Avatar
Kris_23
Was going to say the same thing just nail loads in the bottom of it.
But big risk of contaminating the water I would think!
Old Apr 30, 2009 | 06:25 PM
Kris_23's Avatar
Kris_23
copied from a site
The first general guideline for wood is to boil it for several hours or soak it for a period of time. Boiling tends to kill any bacteria present in the wood and makes the wood water-logged so it will sink. If the piece of wood is too large, many people use a cheap trash can or tub to soak the wood in hot water. Keep adding hot water and scrubbing the wood for several days to a week. Soaking the wood also helps to remove tannins, but this can sometimes take up to a month to remove them thoroughly. Tannins will stain your water, but the amount of tannins leached into your aquarium will depend upon your specific piece and type of wood. You will need to replace the water in the tub every so often and it usually takes about a month for the tannins to reduce to the point where they will not impact your water color. Also, do not bleach the wood as it will be hard to remove from all the crevices and boiling does just as good of a job.
Old Apr 30, 2009 | 06:28 PM
Cossy Mike's Avatar
Cossy Mike
boil it...
Old Apr 30, 2009 | 06:38 PM
Stu.H's Avatar
Stu.H
Originally Posted by saphcosmike
boil it...
How?
The pieces are pretty large!
Old Apr 30, 2009 | 06:44 PM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by Stu.H
How?
How big?
Lambchop's Avatar
Lambchop
PF Idiot Sniper
How?
Cut it up into small bits?
Old Apr 30, 2009 | 06:46 PM
Stu.H's Avatar
Stu.H
Thats a 3 ft tank
Old Apr 30, 2009 | 06:54 PM
Cossy Mike's Avatar
Cossy Mike
Have you not got a big old cauldron?
everyones got one of these man......
Old Apr 30, 2009 | 06:59 PM
Stu.H's Avatar
Stu.H
Yeh pretty sure I have
Ive got a big plastic bin that I could fit it in, but would take some filling with hot water!
Hmmmm.............
Cheers for the replies Mike, apart from the Cauldron one
Pop yours over
Old Apr 30, 2009 | 07:02 PM
Cossy Mike's Avatar
Cossy Mike
Improvise.......Use a really big pan. Buy one from Adsa (smartprice) there only a couple of pounds.
Ask your Mam she'll know what I mean
Old Apr 30, 2009 | 07:06 PM
Stu.H's Avatar
Stu.H
The wont sell em that big!
Old Apr 30, 2009 | 07:09 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
how about sticking the wood to the bottom of the tank with clear silicone before you fill it with water?
Old Apr 30, 2009 | 07:10 PM
Less.'s Avatar
Less.
having a mid life crisis
Boil them in the bath
Stu.H's Avatar
Stu.H
Because you always want to adjust it/move things so it looks right!
Old Apr 30, 2009 | 07:12 PM
Cossy Mike's Avatar
Cossy Mike
You would'nt reach a boil in the bath. Needs to be 100 degrees.
Old Apr 30, 2009 | 07:16 PM
Rob Virgo's Avatar
Rob Virgo
how about lavin it in the boot of a vauxhall for a fortnight.
should just about do it i recon....lol
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
