Sapphire clocks into 3dr ........ question?????????
Old 05-12-2004, 11:13 AM
SteveB
SteveB's Avatar
Default Sapphire clocks into 3dr ........ question?????????
The multi plug in rear is different....... anyone know which wires go where???
When my back sorts its self out i'll get in the garage and look at the wiring on the std plug and compare it to the newer style 1....
Ta
Steve
Old 05-12-2004, 01:04 PM
SteveB
SteveB's Avatar
Old 05-12-2004, 03:53 PM
SteveB
SteveB's Avatar
someone must have done it........
Old 05-12-2004, 08:02 PM
SteveB
SteveB's Avatar
Old 05-12-2004, 08:09 PM
Rob M666SCC
Rob M666SCC's Avatar
I haven't.............
Old 05-12-2004, 08:16 PM
SteveB
SteveB's Avatar
Back to std 3dr clocks it is then.......... b4 it gets wired up wrong and melts summit.....lol
Did someone say Ebay........
Old 05-12-2004, 09:22 PM
Matt
Matt's Avatar
all i know is green one is rpm signal from coil
Old 05-12-2004, 09:33 PM
SteveB
SteveB's Avatar
lol..... 1 down 11 to go then...
Old 05-12-2004, 09:39 PM
Matt
Matt's Avatar
im spent lad
Old 05-12-2004, 09:41 PM
Buy a wiring diagram LOL....
and you work for a tuning company
Old 05-12-2004, 09:46 PM
SPADGE
SPADGE's Avatar
Steve if you have the standard 3 doors clocks there you should be able to tell where each wire goes and what it does from following it around the circuit board!
Old 06-12-2004, 12:19 PM
SteveB
SteveB's Avatar
Dingy......
I'm not at work to look at a wiring diagram (it was a sunday when I posted and hoped someone may be able to help that has done it b4 to save me the hastle of trawling thru the wiring diagrams of the 2 cars)......
Spadge....
not got a std set of 3dr clocks at moment (thats what i was gonna do if I had a set)
What I could do with is a decet photo of the rear of a set of 3dr clocks
Old 06-12-2004, 12:23 PM
B19-TRB
B19-TRB's Avatar
I need to know this aswell!
Steve if u get a wirign diagram any chance of faxin/emailin me it!
need to put my 3dr clocks in2 a mk4 escort efi though! so if u got a wring diagram for that aswell!
Old 06-12-2004, 12:30 PM
SteveB
SteveB's Avatar
Lewis...
when i'm back at work (off at mo due to tearing a ligament "spl" in my back) i'll check the Cosworth manuel and tell you the colour of the 12 wires and what they correspond to, I maybe able to tell you the RST 1 as well but only via the Haynes manuel
Old 06-12-2004, 12:37 PM
B19-TRB
B19-TRB's Avatar
excuses sxcuses! get back to work ya bum!
Im in no rush lol!
r the wiring diagrams in the Cosworth manual then!? cause I got me 1 of them! r they car specific i.e. ssaff, 3dr, esc!?
Its a efi 3i that the clocks will b goin in2! so will c if i can get a haynes manual for 1 of them! unless u got 1 somewhere!?
Old 06-12-2004, 12:40 PM
SteveB
SteveB's Avatar
I dunno about the manuels....... I hoping that it'll give diagrams for the Saff and the 3dr as the plugs on the clocks are different...... I think I may well give up and just buy a set of 3dr clocks....lol
Old 06-12-2004, 12:45 PM
SteveB
SteveB's Avatar
http://www.derbyshire-rsoc.co.uk/cosworthmanuals
B19-TRB
B19-TRB's Avatar
lol
Well i am gunna get a set of 3dr clocks in2 that mk4 if it kills me!
Ryan's gunna cut me off the section of 3dr loom i need! then hopefully its just a case of workin out which wire does what! with both clcok sets there hopefully i cna do as spadge said & just trace the copper wiring round!
3dr clocks r better anyway! boost gauge! (thats the only reason I am fittin them instead of leavin stabndrad clocks!
Old 06-12-2004, 01:11 PM
foreigneRS
Testing the future
foreigneRS's Avatar
is that boost gauge really worth having?
Old 06-12-2004, 01:17 PM
B19-TRB
B19-TRB's Avatar
Yes!
Old 06-12-2004, 01:27 PM
SteveB
SteveB's Avatar
3dr wire colours......
1. BROWN WITH WHITE TRACE
2. BROWN
3. BROWN WITH YELLOW TRACE (2 WIRES)
4. BLUE
5. BLACK WITH GREEN TRACE
6. BLACK WITH WHITE TRACE
7. -----
8. BROWN WITH GREEN TRACE
9. BLACK WITH YELLOW TRACE
10. BLUE WITH WHITE TRACE
11. BLUE WITH BLACK TRACE
12. GREEN
13. GREY WITH GREEN TRACE
Old 06-12-2004, 01:32 PM
SteveB
SteveB's Avatar
Saff wire colours......
1. GREY WITH GREEN TRACE
2. BROWN
3. BLUE (2 WIRES)
4. BROWN WITH YELLOW TRACE (2 WIRES)
6. BROWN WITH BLACK TRACE
7. BROWN WITH WHITE TRACE
8. GREEN
9. BLACK WITH WHITE TRACE
10. BROWN WITH GREEN TRACE (2 WIRES)
11. BLACK WITH YELLOW TRACE
12. WHITE WITH BLUE TRACE
155lee
27-10-2015 04:55 AM
IainRS1700T
25-09-2015 06:44 AM
Kam B
24-09-2015 10:40 AM
tib2220
14-09-2015 12:33 PM
Tony W
09-09-2015 12:08 PM
Quick Reply: Sapphire clocks into 3dr ........ question?????????
