Change fuel pump
Change fuel pump
Im running a 3dr cossie on light blues on a standard pump im going to change the pump cos its the original one on the car is it worth fitting an 044 or keep it to the standard one im keeping it on the blues for the time being
Std will fuel to 400bhp no problem, ther eis very little flow difference between 941 and 044, the 044 has a much higher lockout at 18amps, and 12L/min I think it is, got the graph somewhere.
Fuel pumps dont "Run PSI" as such, they supply a measured volume of fuel in any given time frame and generally supply less and less vaolume as the pressure they are asked to do so at increases. Here are some charts to explain.
Its important to note that the electrical current consumption increases with fuel pressure.
cossie09
14-09-2015 04:21 PM
CabrioTurbo
01-08-2015 11:04 AM
