Yums Dyno Day Today **Result's page 2 & 3**
#162
*** Sierra RS Custard ***
I wouldnt be surpised given how quickly mark seemed to catch it, if it wasnt damaged as it wouldnt have had much time for heat build up, but then again at that sort of level of tune, it doenst take long.
#164
Is there nothing that can work better than a WRC gasket? I realise the demand for a gasket of this level would be pretty low, but in theory is there a better design/material that could be used?
#165
Happily retired
I have no graphs i left quickly cos of getting back to the Missus, who is incapacitated at the mo as you know.
#168
TBH on pump fuel its not really an issue as you'll generally get det before you get enough pressure to make the gasket fail.
#172
well done dave and the m.a.d crew cracking results, the power of that thing must be insane !!!
dave is the car going to get a mag feature ?
good luck with the 200mph crack on the pump fuel
would it be a guniness world record atempt ?
#177
Incredible results
Impressive spool up for such a large turbo
Is it the Autronic boost control that does this?
Would it be possible to achive boost that early with any other boost control equipment?
No nos to help it start reving?
#179
Its the total package that makes it work, Its easy to get it wrong and very difficult to get it right,
You could use other makes of controlers to get the same result,
No nos on this engine and it wont run it as we have more than enough power to brake the gearbox
Mark
#180
And so it should be, Mark invested nearly twenty seconds of his time entering the values for it.
It can do a LOT better than that mate, that was literally just to get it into the right ballpark.
In the car it can also be set so that you get boost based on throttle angle, which can make it VERY easy to drive, even with such monster power, none of the normal cossie problems of you give it 25% throttle and once its spooled you get full boost anyway!
The boost control on SM4 is just superb!
#195
Looks like we are all set for install on Sunday
Marks got to fit new head gasket, also waiting on new sump to come from Harvey
Then its down to me and JB to get it in the hole, anyone else free on sunday that want to pop over please feel free to do so, Helens making breakfast and then maybe afterwards l will do one of my legend bbq's
#196
1st to 200 without NOS
Watch out for a parcel tomorrow Dave.
#200
