lambda sensor question
Old Apr 16, 2009 | 10:56 AM
evo200's Avatar
evo200
Default lambda sensor question
Does anyone know if i can use a std escort cosworth titania lambda sensor with the MSD L8 closed loop software or does it have to be a zirconia type?
are the outputs the same? have got the blanking plug in the housing of my T34 so i'd rather put the lambda there instead of welding a boss in the exhaust.
cheers
pete
Old Apr 16, 2009 | 03:48 PM
No you can't use it.,
The TITANIA are either 0 to 1 volt, or 0 to 5 volts.
The ZIRCONIA are all 0 to 0.9 volts.
Old Apr 16, 2009 | 04:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Dunno but i used my standard saph 4x4 one with my closed loop on L8 .
Old Apr 16, 2009 | 07:55 PM
evo200's Avatar
evo200
is the sapphire cosworth 4x4 lambda sensor in the exhaust or the turbine housing? I dont suppose anybody has the correct ford part number for the saph 4x4 one do they?
cheers
pete
Old Apr 16, 2009 | 07:58 PM
Twellsie's Avatar
Twellsie
cheers
pete
turbine housing
Old Apr 16, 2009 | 08:39 PM
KSA-Cossie's Avatar
KSA-Cossie
cheers
pete
Mine is now in the exhaust as i now run a t34.63,but was in the turbine housing on my t34.48 hth
Old Apr 16, 2009 | 08:59 PM
evo200's Avatar
evo200
my t34 .63 has a blanking plug in the turbine housing, has yours not got one then?
Old Apr 16, 2009 | 09:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Yup but was welding a boss in for the afr gauge so did one for the lambda too.
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
Si B
Sep 12, 2015 06:49 AM
