can brass be welded to stainless
Old 11-04-2009, 07:59 AM
Stu @ Claims Care Centre
Compensation Specialist
Stu @ Claims Care Centre's Avatar
Default can brass be welded to stainless
need to weld my EGT bung to my downpipe ive just found a brass boss for 1/8 NPT as i cant find a stainless one on ebay anywere
Old 11-04-2009, 08:01 AM
Mark V8
Mark V8's Avatar
Brass would probably melt !
You might be able to braze it in or silver solder it but that would melt too, try and find a stainless fitting.
Mark
Old 11-04-2009, 08:04 AM
Graceland
Team HOTHOT!
Graceland's Avatar
Why not goto your local nut + bolt specialist and see if they have what you need in stock?
Failing that, you could use a 1/8" BSP nut in stainless - this is a very very similar thread to NPT and if putting an NPT fitting into a BSP threded hole then the fit is snug and secure
Old 11-04-2009, 08:08 AM
didnt know that as i was looking at nuts but couldnt find any in 1/8 npt but loads in bsp
Old 11-04-2009, 09:17 AM
PGT
PGT's Avatar
a thick type bicylcle valve is also very close to 1/8 bsp / npt
Old 11-04-2009, 09:48 AM
col93saphcos
col93saphcos's Avatar
hi,think npt is very similar to bspt(t meaning tapered thread)bsp is parallel thread,i've an 1/8th npt and 1/4 npt taps if you need a shot,was just a thought you might 1/4 npt to 1/8th npt stainless fitting,will have a look see what tapered fitting i have,maybe some use to you,col93saphcos
Old 11-04-2009, 09:51 AM
i have the 1/8th tap might be able to make a boss myself cheers
Old 11-04-2009, 10:30 AM
Can be braized no bother.
Old 11-04-2009, 10:32 AM
tabs make me a 1/8npt boss
Old 11-04-2009, 11:55 AM
I aint got a tap, but if you have soon knock you one up.
Old 11-04-2009, 12:01 PM
ok well knock a boss with a 8.5mm hole and i can tap it
Old 11-04-2009, 12:57 PM
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
have a look at website called egt from america they do the best egt sensors and sell all sorts of hardware for different type sensors and are very helpful guys
Old 11-04-2009, 07:12 PM
need it fairly prompt ie Tuesday as i want it running for central
01-11-2015 06:53 PM
Quick Reply: can brass be welded to stainless
