Cosworth 4x4 alloy gear shift cradle bushes
Old 10-04-2009 | 02:16 PM
CozzyKing's Avatar
CozzyKing
Default Cosworth 4x4 alloy gear shift cradle bushes
Hi all has anyone fitted alloy gear shift cradle bushes to a cosworth 4x4 at all?
If you have do you think it is a worthwhile moddification?
Old 10-04-2009 | 02:24 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
like these ?
Old 10-04-2009 | 02:42 PM
dojj's Avatar
dojj
Resident Wrestling Legend
will you have a set at the weekend mate?
not that i want this to turn into a for sale add or nothing, just wondering if i should bring more or less money with me
Old 10-04-2009 | 02:43 PM
andy escos's Avatar
andy escos
makes the gear selection a bit tighter but not worth doing unless your taking the box out for other reasons
Old 10-04-2009 | 02:51 PM
graham c's Avatar
graham c
i fancy some of these mite see wot,s at central day?
Old 10-04-2009 | 03:07 PM
Lloyd's Avatar
Lloyd
bring a bit more mate.
Old 10-04-2009 | 03:09 PM
graham c's Avatar
graham c
bring some more and pm me your no so i can ring you at central day
Old 10-04-2009 | 03:11 PM
Lloyd's Avatar
Lloyd
a lot depends how worn the original rubber bushes are,
Old 10-04-2009 | 03:13 PM
dojj's Avatar
dojj
are you going to bump the price up because of demand then
just remember to put my name on a set please
i can say that with even decent rubber ones in place, there is still more movement that i would have liked, with one bolt missing it's damn right difficult to get into gear
and make sure you have thebox out before you start working on it as it's just a little cramped getting your hands into the gaps that don't exist
Old 10-04-2009 | 04:41 PM
Lloyd's Avatar
Lloyd
i have a trade stand at central day mate.
Old 10-04-2009 | 06:50 PM
CozzyKing's Avatar
CozzyKing
Yeah they're the ones mate, I have got the engine and box out at the minute and found that the rubber bushes are no more lol, the damn thing is held together purely by luck so seen them and thought I might ask.
I'm after a set so if they're available on here someone pm me please
Old 10-04-2009 | 07:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Got them on my saph,deffo makes a difference.
Old 10-04-2009 | 07:08 PM
CozzyKing's Avatar
CozzyKing
Just bought a set of ebay so as soon as they get here and are fitted I will give you my input on them.
Whilst i'm on here about it I think i'm gona get a quickshift after reading all the info from Dojj on here.
Old 10-04-2009 | 07:09 PM
BLACKCOS's Avatar
BLACKCOS
got a set on mine well worth the money all day long
Old 10-04-2009 | 07:37 PM
graham c's Avatar
graham c
my quick shift came from a1? ste scott 35 quid off ebay
Old 10-04-2009 | 07:56 PM
dojj's Avatar
dojj
fittign a quickshift at the same time deffo makes it worth while rather than taking it apart again
all you need to do though is make sure that the little bolt underneath is tight enough without being too tight as oherwise you will have wasted all the effort and expense of fitting the uprated stuff as the change will be sloppier than a case of week old yoghurt
and yes, i made that mistake and had to suffer with it
also make sure that the bolts are in nice and tight and you use threadlock on them to stop them working lose
and don't snap the clip rings that hold the selector rod in place
Old 10-04-2009 | 08:01 PM
blacky.'s Avatar
blacky.
the cradle can be removed with the gear box in its just a tight fit
Old 10-04-2009 | 09:45 PM
CozzyKing's Avatar
CozzyKing
Don't worry mate I will carefully follow your instructions before I go ahead and crack on with fitting it all.
Also gotta ask how is the sierra going mate? did you get it all finished by top boss or take it somewhere else?
Old 29-04-2009 | 07:40 PM
CozzyKing's Avatar
CozzyKing
Got the bushes yesterday fitted and all ready for action, I have to say that the difference they have made is fantastic so all I can say is top job indeed.
Old 29-04-2009 | 07:53 PM
paul thornton's Avatar
paul thornton
BMW RS DIESELWORTH
did you take the box out to fit them ?
Old 29-04-2009 | 07:59 PM
dojj's Avatar
dojj
the sierra is still awaiting an oil pipe that split, but it means takig the rack out which means dropping the crossmember as the bolts are too long to come out
you don't need to remove the box but you do need to drop the rear end, which may mean also dropping the exhaust and it's a fair bit of fiddling
Old 29-04-2009 | 08:06 PM
paul thornton
BMW RS DIESELWORTH
do you just remove the gearbox mount,selector etc and drop the box down ? bought some for mine and a quick shift about 6 months ago, just cant be arsed to take the box out to fit them.
Old 29-04-2009 | 09:07 PM
CozzyKing's Avatar
CozzyKing
I had the box out as I had to do an engine swap on the car so my life was made very easy although saying that it would be very easy to do even with the gearbox in place.
Old 29-04-2009 | 10:07 PM
dojj's Avatar
dojj
there is a link in my sig mate
Old 14-09-2018 | 05:20 PM
Thread revival....
Are these alloy bushes good then or am I better off fitting poly bushes to the gearbox cradle. I've been messing about with my car and noticed the gearbox cradle is really sloppy.
Old 14-09-2018 | 07:48 PM
The Youth.'s Avatar
The Youth.
very worthwhile Glenn, next time your passing the unit and i'm in come and try the race car that has the alloy ones fitted and a quickshift knuckle, make it feel much better.
its a gear box out the to do, (you can do it with the box in but its too much grief)
Steve
mk3 fiesta cosworth
23-08-2015 11:31 AM
Anutternutter
21-08-2015 07:07 PM
charliecosworth
19-08-2015 03:00 PM
cossie4x4
14-08-2015 07:29 PM
14-08-2015 08:29 AM
