cvh solid lifters help adjustment fitting help ?
Old Apr 7, 2009 | 04:37 PM
matty325's Avatar
matty325
Default cvh solid lifters help adjustment fitting help ?
hi i have just bought a second hand stage 2 head fitted with a kent cvh 34 cam and my mates offered me a set of solid lifters i dont know much about them can you fit solid lifters to this cam and does anyone know how to adjust them ,cheers for the help guys !
Old Apr 7, 2009 | 05:01 PM
You can fit solid lifters to any cam really, what's more to the point is do you need to ?
If it(cam) doesn't need solid don't fit them as it is just hassle adjusting, whereas a hydraulic does it all for you.
The solids are used with either mega profiles or where very extended(above normal) rpm is used.
If the profile is hydraulic then solid will give no advantage whatsoever.
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
155lee
Aug 14, 2015 11:21 AM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
