nos
nos
i just dropped a 5lb bottle off to be filled and the guys said i would be lucky if it gets me down the 1/4mile once!! but i really dont no so has anyone yoused a 5lb bottle its a 2.0 16valve turbo on 25hp jets
I have a 5lb bottle with a WON 50 bhp setup and I get just over 60 seconds out of it, so that should see you a few runs up the strip I would have thought!
Give it a go and find out
And if you use it in an anti lag setup it should last even longer.
You know that 25 in on a turbo'd ebngine usually equates to a 50bhp increase?
p.s wont be using it as anti lag .
escort mk4 cossy 4x4
Dunno if its an urban myth or not but I heard they stored pressurised liquid oxygen in the tubes of the roll cages in rally cars many moons ago
if u remember right lol was told by WON that an 11lbs bottle will last around 11 minutes with 25 shot jet.
so your full bottle should last around 5mins if the system is setup proper
good idea to have a heater blanket with pressure switch to keep the pressure of the bottle the same all day
Happily retired
11lb bottle is Ł66 now & can get just over 1min of usefull Nitrous from that with 200bhp jets thats nearly Ł1 a second . Dont believe all this double the horsepower nonsense on a RR 50bhp jets gave 45bhp.
*** Sierra RS Custard ***
So both trevor and rod are correct based on my experince of it, they are just each talking about a slightly different aspect of it.
Also the worse your intercooler, the more power you will gain of course, as the extra gains are largely about the cooling effect.
ive got some 50 jets and was planing on taking them with me , but was worried if it hits the rev limiter when it comes in and spins the wheels up as i was told this is not good???
p.s if does a 15-16sec 1/4 ill burn it at the bottom of the strip lol
turbotrev
39
17-04-2016 09:03 PM
