General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
You be able to get a pattern one for a fraction of that.
Just looked at some intermotor ones and they only about £25 + vat.
Pattern Cossie ones are about £100 + vat
No idea about gen ones though, any local factors should be able to find you a pattern one.
Im sure they are the same as the Lancia deltas.Whats wrong with it mate,is it reving up and down all the time.Mine used to do this and i got told to lub it with somw brake fluid and its 100% better now.
9 times out of 10, if the idle is raising and falling the iscv is working perfectly, as thats exactly what its supposed to do....its just being fed the wrong information by the ecu, and there are several causes of that.
When idling the revs wander now and then. Sometimes you pull up and it'll wander from 900-1200rpm and other times you pull up and it just sits perfect at 900rpm.
Im sure you can get a sensor kit off matt for about 50 quid and you get the crank sensor air temp sensor and water temp sensor.Have you had your base idle set too.
Nothings been touched on the car since new, it's covered only 40,908 miles. I have replaced with new genuine parts,
Distributor cap (Black MM)
Rotor arm
HT leads
Coil lead
Group A coil
Water temp sensor (dash)
Phase sensor
Spark plugs
Radiator
awaiting phase sensor in the post and I have just ordered
New phase sensor fitted tonight. The car now idles like a pile of shite it keeps cutting out. I held revs up to 2500rpm until it warmed through. It then seemed the same as it was before.
I am hoping it's just the battery thats weak. Ive left it on trickle charge over night.
I removed the ISCV and there seems to be nothing to it. The 'o' rings are fine so I re fitted it for now.
I am hoping it just needs a good run out as it has'nt been out since before Christmas.
ECT sensor coming tomorrow. How much coolant will I loose removing it?
hi m8 i had the same thing with my 3dr the week end it means its just sticking m8 take it out get small screwdriver and keep pushing the inside up and down and try and turn thee inside around if u can ad a little wd40 wile u do it m8 then try it mine was reving up and dowm did this as my bro told me what 2 do and it now works perfect now good luck
hi m8 i had the same thing with my 3dr the week end it means its just sticking m8 take it out get small screwdriver and keep pushing the inside up and down and try and turn thee inside around if u can ad a little wd40 wile u do it m8 then try it mine was reving up and dowm did this as my bro told me what 2 do and it now works perfeck now good luck
I had it out of the car and in my hand about 2 hours ago. I could not see what had the movement on it. It had like a threaded end sticking out with a tiny nut on the end.
What bit do I 'work'?
give me a bell m8 and ile tell u what 2 do 07813855364 dave
