Mk3 Mondeo Floor Damp
It was also a issue on the mk1 mondy, as I had it.
I sealed mine 100% perfectly with LOCTITE 5900, the rest of the tube can be used on anything on the car around the house etc, awsome stuff, if a little pricey, gave away all my hylomar the 1st time I used this, not looked back since.
normally on mk3 mondeos we see leaks from door trim membranes or speaker mount behind door trim.the mastic comes away at bottom of the door causing the leak.take off door trim from whatever side your noticing the leak and do a quick water test on it.failing water test put your hand around the membrane to see if any part if coming away
How does the water get down the door i thought that if there was water in the door it would go out through the drian holes at the bottom on the door
Brian
Resident Wrestling Legend
I have removed the door card tonight and the membrane looks ok it seems sealed all the way round with some sort of black mastic
Brian
Brian
if it's rained hard when i open the door there is a trickle of water thats caught in the rubber that drips along the sills
I see this everyday at work Brian, you will need what the techies call 'Bootle and 2' - approx 4ft of bootle tape, available from ford and 2 clips to hold the pollen filter housing on. While your there you may as well change the pollen filter too. Any probs drop me a pm on here or the fiesta club and i will sort some out for ya and post it mate.
Thanks mate
Brian
mk3ste
17-10-2021 10:09 AM
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
