cossie fuel rail
30-03-2009, 04:28 PM
cossie fuel rail
are the 2wd and 4x4 diffrent?
i know the regulators are diffrent
30-03-2009, 04:30 PM
30-03-2009, 04:37 PM
its easy to fit with brackets if you wanted to mix and match
30-03-2009, 04:42 PM
Passion for Fords!
yes col ,the mounts are in differnet places, or one of them is...
30-03-2009, 05:16 PM
30-03-2009, 05:30 PM
you may not be able to shut your bonnet if you use a 4x4 fail as the reg is high up!! i can couldnt on my escos
30-03-2009, 05:31 PM
Passion for Fords!
Quote:
Originally Posted by
dom123
could you not hammer a power bulge into the bonnet
30-03-2009, 05:40 PM
what you needing col?
a 4x4 rail or a 2wd inlet?
might have something nocking arounf if your stuck
30-03-2009, 06:03 PM
i was just needing a 4x4 for the saph but gone on here for Ł15,and i have a 4x4 regulator
cheers jamie,what i do need is the associated fuel hoses/pipes,ie pigtail 1 etc if you can help?
30-03-2009, 06:08 PM
Col i should still have a complete 4wd rail and hoses sitting at ava if your stuck.
30-03-2009, 06:13 PM
aye that be helpful neil,cheers mate
30-03-2009, 07:45 PM
The 2wd one has a fitting with a hose that goes to the regulator, and the fitting at the back that comes from the pump, the 4wd one is the same at the back, but the regualtor actually mounts onto the rail and has an o ring at the front. Also the 2wd and 4wd have different mounting points.
30-03-2009, 08:24 PM
THIS is a 4x4 inlet with a 2wd rail on it as you can see from the photo i had a second lug welded on so i could fit it
30-03-2009, 08:52 PM
think i cut mine off col
might be as well just getting neils at ava
30-03-2009, 09:05 PM
iv cut the 4x4 one off now to as i wont be needing it but iv put the lug away as you never no when you might need one
JK12
33
26-04-2021 12:09 PM
Cossiesteve
Ford Escort RS Cosworth
17-09-2015 12:37 PM
kevin36
08-09-2015 12:23 PM
Thanasis
07-09-2015 07:33 PM
