General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
need some new braided flexi brake pipes for the front of my car just starting to look a bit swollen at the end. whats best to go for ? my calipers are bigger ap 4 pots from a morgan aero 8 will they be the same as normal cos conversion ap 4 pot 330s ?
anyone ? ive found some kits on ebay from mattlewis but there for standard calipers and i dont know if the fittings are the same thread in ap calipers ?
Get the bits from Burtons and make some up yourself.
Dead easy to do.
i dunno what fittings i need though mate ? just had a look at the car and the pipe on it is a 1 piece goodridge hose no adapters on just straight from caliper to original brake pipe.
the AP have a banjo connector at the caliper end, probably easier to order some from a trader on here, unless you have a hose/hydraulic place nearby, pop one of old ones in & they will make another set up.
defo different then mate mine isnt banjo just a threaded hole in caliper by the looks of it.
worded last post abit wrong ment to say threaded hole in caliper and straight pipe with fixed end screws straight in. caliper must be the same as morgan aero 8 as pads from morgan were identical and only cross reference pad that was the same. i had to send ebc an exact diagram for them to match when i needed pads !
