Connect Van , please help
Old Mar 25, 2009 | 06:41 PM
THE MAD RKH's Avatar
THE MAD RKH
Default Connect Van , please help
Hi, Anyone here have a Ford Connect Van??
Need info on what size & offset for some Comp 5 spokes
And also info on lowering this. I have a Focus RS and aware that to lower mine I need to change the springs or go for coilovers but I have heard that the Connect suspension doesn't work that way?? So how do we go about lowering a Connect?
Any help much appreciated
Old Mar 25, 2009 | 08:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
same as the rest of the focus mk2 and mondeo mk3 range at teh front
same with the wheels and offset
Old Mar 25, 2009 | 08:48 PM
Icurus's Avatar
Icurus
Leaf springs on the back too
Old Mar 25, 2009 | 09:04 PM
focusv8's Avatar
focusv8
Use blocks between the rear beam and springs and longer U bolts.
Old Mar 26, 2009 | 02:03 AM
THE MAD RKH
CheeRS for the replies but,, Frankly, I'm none the wiser
Dojj; I don't know the spec. of a Mk2 Focus or any Mondeo I have a proper Focus ha ha
Icurus; If they got leaf springs on the back too, u mean they have leaf springs on the front too??
FocusV8; 1st. Wow have u really got a Focus V8??? Cool As!! RWD??
Do we have an idea about how much it would cost to get a Connect lowered at a Tuners/Garage, Please??
Old Mar 26, 2009 | 02:39 PM
dojj's Avatar
dojj
5 stud 108 pcd rims
so whatever will bolt onto a mondeo mk3 or a focus mk2 will also fit the connect
first thing to do though would be to source some mk3 mondeo stoppers and bolt them onto the front and then get some brackets made up for the rears if the hubs won't fit
then you can have some fun
bvut you need 16inch wheels first
Old Mar 26, 2009 | 08:16 PM
focusv8's Avatar
focusv8
Originally Posted by the mad rkh
if they got leaf springs on the back too, u mean they have leaf springs on the front too??
..no
focusv8; 1st. Wow have u really got a focus v8???
...yes
Rwd??
....yes
Old Mar 26, 2009 | 08:25 PM
jacko's Avatar
jacko
im putting a rear beam from a st3 in mine
oh and the engine
Old Mar 26, 2009 | 08:28 PM
Icurus's Avatar
Icurus
the rear beam sits above the leaf springs, so its not a case of using lowering blocks like you would with a mk2 Escort.
Old Mar 26, 2009 | 08:34 PM
focusv8's Avatar
focusv8
Think about it or draw it.
The rear beam always stays at the same height, the wheels define that.
Put blocks between the beam and spring and the spring which is attached to the body is forced down closer to the ground, taking the body with it.
Old Mar 26, 2009 | 08:39 PM
jacko's Avatar
jacko
just put a focus setm up in it then it will even drive nice
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
stevecfrst1
Sep 30, 2015 05:18 AM
