Off topic help required - petrochemical industry specialists
Has anyone got any contacts in this field, as I am trying to source some LF60 steel plate, for a job we are pricing for. I can't find anyone anywhere that can help - I've tried google etc and all the usual steel companies in this country, but to no avail.
Anyone in this industry (like the offshore bods, perhaps engineering peeps contacts?) know where I can find some pretty please!?
Originally Posted by justin.e
Mike,
try Rob they store lots of IPA and other dangerous crap where he works the funny thing is he's on the safety team
go on then Mike , what is LF60 ???
I presume that its a steel exceptionally resistant to corrosives ???
try UKF stainless , bassed in brum , may have no isea what u want bit i find that they have all the odd , wiered and wonderfull stuff thet i need for jobs
01527 578687 speek to Simon or dave smith
Still can't find any plate, but managed to find a 20" sch 120 (39mm wall thickness) piece of LF60 tube (there is only one 6.9m length in the whole of the country and it is a mere Ł1,650 + VAT per metre ), but as this is going to be a saddle it is the wrong radius . Back to searching for some plate (to be pressed - as it is too thick to roll) . LF60 is actually a heat treat flange material (quenched and tempered), but as this is going to the petrochem industry in Nigeria, the saddle has to be made of a similar spec material.
Location: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Mike, try Anglia Alloys on 01493 651028, and Middleton Heat Treatments on 01502 561721. Could you get some standard plate heat treated to the same spec?
You mean the one that does his special thing on your special thing on your special car that comes from a country far, far away?
If yes, you have to realise that the two pieces of flat that I want will weigh half a ton EACH - can you imagine the carriage from there? .
Mike I went out and spoke to a supplier of the offshore ind. They stock LT60, but aren't too sure of LF60 , do ya mean LF60.
Mike,
Yes I definitely need it to be LF60 (which is the material type the flanges are made out of - 10" 1500lb RTJ/long weld neck sch 140 - mat LF60 (quenched and tempered)). I think you will find that LT60 will be a different grade, as we have already been offered some LX60, which isn't the correct spec either.
PM what your making and i'll have a word with my material supplier to see if there is any other material you could use as they make everything you could ask for out of metal.
Fozy,
We are quoting to make a saddle for a pipe to enable the a tee to be cut into it without cutting the pipe apart. I just need to source some 35mm thick LT60 (or equivalent, as this is a flange material spec). It isn't subject to particularly high pressures (only 190 bar max, but has to be tested to 285 bar), but due to it's application (oil & gas industry), it must be of this type material.
Jeebus
Mike, try these. Not 100% sure that they have it but they are worth a try.
Steel Express Ltd
Unit 1
Berkshire Crescent
The Woods Estate
Wednesbury
WS10 0SS
Tel 0121 502 6366
If not look in Kellys and get ringing!
Steel Express Ltd
Unit 1
Berkshire Crescent
The Woods Estate
Wednesbury
WS10 0SS
Tel 0121 502 6366
wowk
30-03-2021 07:49 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
