Ford Focus 1.8 TDCI Fuel Filter
can some 1 plz help I have fitted a new fuel filter to my 2002 1.8 tdci focus and got fuel all the way to the injectors but still will not start the engine just keeps turning over till the battery goes flat can some 1 help
![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/wall.gif)
connect the red ended pipe to the filter and connect the pipe which goes back to the tank. then suck the fuel from the other connection on the filter.
best thing to use is a hand primer pump, but make sure this is working ok.
just cos you have fuel at the injectors (you really shouldn't be cracking of injectors on a tdci anyway) don't mean theres not air in the system.
I have sucked the fuel form the other connection on the filter using a hand primer pump I then to took the primer pump of the connection and put the one of the car back on the filter and tried start the car it would not start, does it take a long time for the car to start also when I took the primer pump of the connection the fuel just went back in to the filter some one plz help
I have now got my car started I had to a diagnostics check and found out because I tried to bleed thru the injectors I had messed up the fiering order so never ever bleed thru the injectors
