diff problem again 2wd saph :( uploading vid now
Old Mar 21, 2009 | 12:52 PM
scoooby slayer's Avatar
scoooby slayer
Default diff problem again 2wd saph :( uploading vid now
just got home had a 3000 mitsubishi thing wanting to play so thought itd be rude not to blow him away
anyway full thottle loosing traction in 2nd and 3rd but all seemed good. once i started cruising to come home hearing a load whining noise from the diff hasnt failed like the others did just very noisy ?
ive recorded with phone the noise as a vid just uploading it now.anyone any ideas what would cause this whine ?
it doesnt whine when sat at set speed, only whines when gently accelerating then stops as soon as off the throttle. i havnt full throttled it since i heard the noise but tbh i wont hear it whining when im on boost anyways as engine noises are too loud.
Old Mar 21, 2009 | 01:04 PM
ybturbo's Avatar
ybturbo
Where 's your video link?
Old Mar 21, 2009 | 01:06 PM
scoooby slayer
vid wont upload too big i think. definiteley a whine though just wondering what would cause it, and if its gonna fly to bits again !
i think ive gotta accept ive got too much power for a standard diff as this one hasnt had 1 launch yet only full throttle after rolling !
Old Mar 21, 2009 | 01:16 PM
james kiely's Avatar
james kiely
the big question is did you blow the mitsy away young man
Old Mar 21, 2009 | 01:19 PM
ybturbo's Avatar
ybturbo
If the noise is coming from the diff then maybe a bearing failed or a stripped tooth. I had same problem and it was a stripped tooth from the pinion gear (that didn't stack between tooths since your diff is still running). This results to a whining noise...
I hope that this will help!
Old Mar 21, 2009 | 01:26 PM
TiB's Avatar
TiB
Jack the car up and turn the prop backwards and forwards to feel for backlash in the crown wheel and pinion.. if you have play then thats prob why its whining as it will be 'out of mesh', either way though its a case of diff out and sent to the transmission place to be fixed or if its a std diff it might be worth looking for a good replacement.
And if you have a spare diff it would be rude not to send it away and have a quiafe ATB fitted to it.. one of the best mods i've ever done to my car. (the track boys will say get a plated but for fast road use i think quaife is better)
Old Mar 21, 2009 | 01:48 PM
TurboShed's Avatar
TurboShed
Cossiemodo
vid wont upload too big i think. definiteley a whine though just wondering what would cause it...
Don't worry.
It probably just means it's knackered and you need a new one
Old Mar 21, 2009 | 05:57 PM
scoooby slayer
completely mate said 3000 gt on the back whatever that is ?
Old Mar 21, 2009 | 05:59 PM
scoooby slayer
still standard mate thats 3 now in 1500 miles and thats with no drifting at all and only 2 launches
every launch ive done in it has smashed planet gears instantly
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Gadget
Aug 13, 2015 08:19 PM
ray barker
Aug 7, 2015 09:00 AM
