lotus engine
Old Mar 13, 2009 | 10:52 PM
rspeter's Avatar
rspeter
Default lotus engine
hi were can i get parts to do up a lotus engine it a 907 block
Old Mar 14, 2009 | 12:06 AM
Maria.'s Avatar
Maria.
Hi Welcome to PassionFORD.
Not bad for a first post!
Maybe you'd get a few more answers if you targeted a LOTUS orientated forum.
Old Mar 14, 2009 | 12:20 AM
alistairolsen's Avatar
alistairolsen
Which lotus engine? If its a twink then its a ford block afaik
Old Mar 14, 2009 | 12:32 AM
richm's Avatar
richm
907 is the later all alloy slanted engine, used in various derivitives in Jensen Healey, Lotus Sunbeam, HSR Chevette, Esprit to name a few
Old Mar 14, 2009 | 08:39 AM
rspeter's Avatar
rspeter
it one of fords old engines it the twin head 907 block thaught it would look good in a mk1 escort any help to source parts would be grateful thanks peter
Old Mar 14, 2009 | 08:50 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Just go on Google their are a few places out there.
Spent a few years working on these babies is it a 2.0L or a 2.2. Have modified both the earlier 2.0 is by far the better engine.
If you can keep the Delortos in tune for more than 2 minutes its a great little engine. The later Turbos were designated 910 I believe, best of luck.
Old Mar 14, 2009 | 09:09 AM
900ss's Avatar
900ss
RWD Racer
Chucked a complete eclat away the other month, less carbs mind lol
Old Mar 14, 2009 | 11:19 AM
rspeter's Avatar
rspeter
hi madrod were did you get the parts, what carbs did you run on them, it the 20L one
Old Mar 14, 2009 | 01:27 PM
jammy86's Avatar
jammy86
912 I thought... Although the turbos might have been called something different from the NA ones. I'm sure the Slant is the 912. If anyone is after 912 parts I've got a mate with one which has a bad bottom end, but is complete and has had the head rebuilt recently. We're sticking a 1uz-fe int he car instead.
IMHO your aswell converting the car to another engine as the cost of a new Zetec and conversion could be done for less than a full rebuild thats only going to last 10k miles.
JAmes.
Old Mar 14, 2009 | 02:01 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Also known as the naturally asperated "Lotus 910", the stroke was increased to 76.2 mm giving a displacement of 2.2 L (2174 cc).
910
Turbocharged engines introduced in 1980 were known as the type 910, which in high compression configuration produced 215 hp (160 kW) and an astounding 220 ftˇlbf (300 Nˇm) of torque. The engine was again upgraded in 1990 to the type 910s for use in the Esprit SE where it produced 280 horsepower (210 kW) .
Old Mar 14, 2009 | 11:31 PM
rspeter's Avatar
rspeter
thanks guys for all your help if yours find out any more about it let us know thanks peter
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
knight19770
Aug 4, 2015 12:36 PM
