FIXED:Cossie dash not working, no temp, no RPM no battery light??
We were doing some stuff to the car tonight and have obviously upset something. The car runs fine, but there's no coolant(temp), no RPM, and No battery light when the ignition is on????
Car runs fine and RPM is displayed on the SECS monitor as normal.
EVERYTHING else seems to work ok, lights etc, even on the dash seems to be fine, just the dials are not showing anything????![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
It's a 4x4 saph BTW
It's a 4x4 saph BTW
More boost Igor!
If you've got access to another set of clocks try those. ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Does the fuel gauge work? Mine doesn't - by the sounds of your gauges yours and mine were put together by the same man at the factory![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
The battery light could just be the bulb needing turning around a bit more
Also try re-seating the multiplug on the back of the clocks.
Could be the loom plugs on the bulkhead Rog ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
If you have been messing around there and moved them that could cause all sorts of issues. I know it played havoc with my dash in my saff once id disconnected them.
Thanks, looks like i'll have to have a poke around to see what's what.....
We did some work near connectors on the bulkhead, that was the first thing i tried when i realised there was a problem. I just remembered though, the wires for the windscreen washer jet had come loose, so i was messing around there too.
track.focus'd
12-08-2015 05:53 PM
