Bars Leaks... FANTASTIC !!!
rich_bloor@hotmail.com
i tracked my leak down to the raidator....
https://passionford.com/forum/showth...50#post3978850
I was looking at a new raidator, but i thought i'd try some Bars Leaks first.
its worked, been on a run in the car, thrashed it a bit to test it, its still not leaking.
Bars Leaks... RECOMMENDED !!!
Chasing Radders
-WELL said
Bars leak is good for a quick fix......but get the problem fixed not masked
Team HOTHOT!
Some previous owner twat put this shit into the coolant system on my old L200 to try and stop the heater matrix leaking - it didn't work, it clogged the core of the radiator and I ended up having to fork out for a new water pump, thermostat, radiator and heater matrix + assorted coolant hoses
and it also clogs up the rest of the core and drastically reduces efficiency of the cooling system. You'll need to run some rad flush through the engine before you change the radiator - it's such a ball ache to get rid of.
Bars does indeed block, and it doesn't last.
KALIMEX K SEAL does NOT block and can last indefinitely, I know vehilces over 5 years old treated with this, one wasa a cracked head(waterway) that is still good as new, despite having had subsequent a/freeze done.
K seal contains ceramic fibres though, don't think the others do.
155lee
24-10-2015 11:11 AM
Cos500
16-09-2015 09:50 PM
Tony W
09-09-2015 12:08 PM
