help needed bleeding transit diesel! - fixed :cry:
Old Feb 26, 2009 | 04:34 PM
xr-stu's Avatar
xr-stu
Default help needed bleeding transit diesel! - fixed :cry:
got an ldv with a 2.5 transit non turbo lump. a mate told me to drain the fuel filter as they collect water, and ask mine had been sat for a while and didnt want to start this morning, it sounded about right. he thought they were automatic bleeding, but since dropping the arse of the filter out to drain some of its contents, the van cranks over, fires/coughs and thats my lot, so im assuming i do need to bleed it.
how do i do that?!
took out the little bung on the top of the filter head thinking that would alow any air to escape, but there seemed to be only a very tiny ammount of air in there.
theres no plunger, no bulb, no lever to pump, the only thing i can see that may be of some use to me is a nipple looking thing on the left of the fuel pump, would this be where i bleed it from? if so whats the proceedure?
Old Feb 26, 2009 | 04:36 PM
Graceland's Avatar
Graceland
Team HOTHOT!
turn igniton on, remove bleed screw at top of filter housing and then the electric in-tank pump will fill the filter up and expell any air out of the bleed screw hole
Old Feb 26, 2009 | 04:43 PM
xr-stu's Avatar
xr-stu
right-o will try that! cheers!
Old Feb 26, 2009 | 04:49 PM
xr-stu's Avatar
xr-stu
just loosened it off and left ignition on and nothing seemed to happen, cranked the engine over and it started leaking fuel, tightend it up, cranked engine, coughs and splutters but wont catch and fire properly.
Old Feb 26, 2009 | 04:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Keep trying - it will fire eventually
Old Feb 26, 2009 | 04:51 PM
rs-tuner's Avatar
rs-tuner
did you take the filter off
Old Feb 26, 2009 | 04:55 PM
xr-stu's Avatar
xr-stu
i didnt take the filter off, i just took out the plug in the bottom of the filter to drain the contents, then screwd it back in again.
Old Feb 26, 2009 | 04:58 PM
kev 3dr's Avatar
kev 3dr
Fill the filter back up with diesel and crack all the injector pipes off and just turn the engine over till fuel shoots from pipes then as your turning the engine over tighten one pipe at a time !!
old shape transits are non electric fuel pump fed !!
Old Feb 26, 2009 | 04:59 PM
rs-tuner's Avatar
rs-tuner
make sure its tight these are bastards for drawing air in. oh and in future if its not broke leave it alone.
Old Feb 26, 2009 | 05:04 PM
xr-stu's Avatar
xr-stu
it wasnt firing this morning!! was cranking and cranking and cranking with the odd chug! fucking stupid as it ran beautifully yesterday!!
will try bleeding the injectors tomorow, i cant be arsed with it tonight now.
Old Feb 26, 2009 | 05:10 PM
nickywarwick's Avatar
nickywarwick
crack the injector pipes off & turn it over till fuel is spitting out of them tighten up 1 by 1 & she'll be sported mate.
Old Feb 26, 2009 | 05:24 PM
xr-stu's Avatar
xr-stu
cheers ill do that tomorow. fuck arsed about last night in the dark with the starter, cant be arsed to do the same tonight.
dont mind working on cars but when its cold, dark and youve not got a clue whats wrong or what youre doing, it pisses me right off
Old Feb 26, 2009 | 05:29 PM
Jimbo's Cossie's Avatar
Jimbo's Cossie
Had one of these shows the dead pump syndrome when the filter had work done on it. getting common now but we dont see many in at ford now, back street garage beat our prices by far.
As mentioned, loosen pipes at the injectors and turn over until fuel has a steady flow and re tighten.a second person turning it over will make it alot easier
Old Feb 26, 2009 | 05:34 PM
xr-stu's Avatar
xr-stu
you saying it could be a dead pump? or just gives the symptoms when theres air in the system?
Old Feb 26, 2009 | 05:45 PM
MrMPuk's Avatar
MrMPuk
Not bloody likely. Mechanical lift pump.
Old Feb 26, 2009 | 05:47 PM
fordghiarsxrboy's Avatar
fordghiarsxrboy
fill the filter with derv get a mate to crank it and spray some easy start in the intake.should fire no probs.
Old Feb 26, 2009 | 05:51 PM
nickywarwick
will just give the symptoms mate, turn over for yonks if thers air in the system. just get a mate t turn it over & crack of the injecor pipes. peice of cake.
Old Feb 26, 2009 | 06:22 PM
xr-stu's Avatar
xr-stu
im assuming if i just loosen the injector pipes rather than totally remove them, then let it crank for 10 seconds or so, this will be enough??
Old Feb 26, 2009 | 07:15 PM
whosyadaddy's Avatar
whosyadaddy
yes mate just loosen them and when it starts pulsing fluid out tighten them off as said one by one.
Old Feb 26, 2009 | 08:21 PM
xr-stu's Avatar
xr-stu
sweet, sorry for my ignorance but im assuming i should tighten them off as the engines cranking over? or can i stop cranking the engine and then tighten them?
Old Feb 27, 2009 | 01:39 PM
xr-stu's Avatar
xr-stu
ok so i have my lunch the drag all my tools out the garage to get on with trying to get this cunting van to start.
i pop the bonnet, look at the injector pipes and think "urgh FFS" then something catches my eye, the rod that runs between the metering head and the choke/throttle type valve on the intake is disconnected, not good i thought. connect it back up then look at the other end, choke/throttle/intake side, and the linkage is 1/2 hanging off, causing the valve to be stuck 100% shut i plonk it all back on properly, think hmmm lets try my luck....crank it over, fires first time
obviously knocked it off while i was throwing my toys out the pram fitting the new starter/battery
anyway its running sweet as a nut now without having touched the fuel system
Old Feb 27, 2009 | 01:59 PM
MrMPuk's Avatar
MrMPuk
Best thing to do is remove the linkage totally and cable tie the butterfly valve open or remove it totally, will give you more power.
Old Feb 27, 2009 | 02:01 PM
xr-stu's Avatar
xr-stu
surely its in there for a reason though? aid cold starting perhaps as it doesnt seem to have glow plugs....
Old Feb 27, 2009 | 02:57 PM
You comic lol.There is nothing worse than forgeting to put a part back together and trying to start the vehicle.
Old Feb 27, 2009 | 04:06 PM
xr-stu's Avatar
xr-stu
i didnt know id knocked it off!!
Old Feb 27, 2009 | 06:16 PM
whosyadaddy
At least you got it sorted and learned something new in the process mate!
Old Feb 27, 2009 | 06:41 PM
999's Avatar
999
the egr mod is a good move however taking flap out or clampint it open makes em noisy on tickover etc, i just run injecter cleaner every other month and stick at that, depends on how coked up your inlet is etc, if its not broke dont fix it, if you need a tad more power you can do a slight adjustment on the pump takes 10 mins, i turn all mine up a little
Old Feb 27, 2009 | 08:04 PM
xr-stu's Avatar
xr-stu
power wise its alright, doesnt struggle on hills or whatever, i probably wont bother.
it does struggle to start from cold though, took a couple of attempts earlier....
jay030787
Aug 17, 2015 06:16 PM
taylora1409
Aug 12, 2015 12:06 PM
Mark RS
14
Aug 11, 2015 11:45 AM
Fil
14
Aug 10, 2015 07:42 PM
col93saphcos
Aug 7, 2015 03:21 PM
