my boot relaease does not work?? any ideas? fiesta rs!
![Question](https://passionford.com/forum/images/icons/icon5.gif)
hi guys, my weak side of my car is electrics, basically the boot release does not work in my fiesta rs turbo at all, i have changed the boot switch, purchased a new ignition relay, cleaned the earth for the boot popper and bought the new 4 pin sinsor which screws into the boot!
any other ideas chaps
You ever sort the problem?
Ive just bought a new green relay as one contact had slightly the fusebox. The new relay works only with the rad fan/heater fan/reverse light. But If I refit the other relay only the boot switch will work. The foglights won't work with either relay. Everything did work before I removed the green relay to check why my heater fan screeches
The new relay has a slightly different part number mind(I have yet to try ford direct).
JoeyBoyden
04-01-2024 02:36 PM
