Can someone get this down to the 35kb limit as the sig police are on my case
As title.....
Sizes are ok, just need to get it to 35kb without loosing the quality as i have had it removed.
The compresser thing that they use wont work for me
for the past several years, i've had a spinning khanda like this
under my name
then i was told it was too big and so it was removed
not a problem, if it's too big, it's too big, but trying to resize it has ben a problem, so i've not had it put back on again
so, i may have to contend with no spinny thing spinning under my name unless someone can make it the correct size for me
if you can i will thank you and give you a well done
under my name
Tiff, I got banned from Briskoda as I was asked to reduce the size of my sig, which I did. Then I got told to reduce the file size, which I did. Then I got infraction points and had the sig removed again.
So I sent a message showing all 3 sigs I created and uploaded showing the different sizes, etc and told the bloke he needs to grow up! If I made no effort to sort the sig I wouldn't mind, but I tried twice before and he sent me an arrogant message as if I never even bothered. Told him that if my sig was incorrect they should advise me on how to correct it as Im not a PC Guru or do it for me as if it bothers them that much.
Now Im banned with no reply or explanation, so they do need to grow up as I stated
Anyone can post a picture up of anysize yes? So why not just have the {img}blahblah{/img} to hand and copy and paste at the end of every post. Not technically a signature strip then as it's above that little black line...
Then the forum would grind to a halt. These rules are actually there for a reason.
sig police had me too !!
i just dont get how if the picture is within the max allowed sze it can be too big ? how does the file size change without changing the actual size ? i can just about work my way around ms paint so the chances of me getting it right are pretty much zero
heres the one i had
heres the one i had
heres the one i had
heres the one i had
You need to save that and rehost it!!
every days a school day - never knew what that symbol was called.
Thats well harsh!! only common grace to give an explanation aint it!!
The day after I sent the PM I clicked on my link and got:
Your password is 270 days old, and has therefore expired.
Please change your password using this page
When I click the "This Page link" I get:
$bbuserinfo[username],
You do not have permission to access the forums, because you are $until.
$vboptions[bbtitle] Team
Log Out Home
When I use the Log Out or Home links it goes to Web Page Cannot Be Found. Bloody childish and I will complain if I ever get reinstated I have sent a message to the Website owners to explain why I cannot use the website
Log Out Home
you only had to ask
i was made aware that it was too big, it was removed, i can't quite rememebr where it was hosted but that's neither here nor there
it was too big end of, but at least soemone informed me which was nice
now i can look for ways to solve the problem
dojj
go to http://www.gifworks.com/cgi-bin/gifw...=transfer_open
put in the address of your spinning khanda ( http://www.clufoir.com/Gurudwara/spin_khanda.gif )
and you can resize it, and save it back to your desktop for re-uploading
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
