Viscous Diff
Old Feb 3, 2009 | 05:16 PM
Paul_RS's Avatar
Paul_RS
Default Viscous Diff
Quick question about them, can you rebuild them? If so how? By rebuild i mean 'retighten' them?
I believe you can, just don't know how its done.
Old Feb 3, 2009 | 10:08 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i think the gear people called bara can do this for you.try contacting martin at reyland.
Old Feb 3, 2009 | 11:28 PM
stevieturbo's Avatar
stevieturbo
C**t
The Viscous fluid in them can be changed. Special job though.
Some guys on J44 claim there are people here that can do it. I find it hard to believe though.
Old Feb 3, 2009 | 11:34 PM
Kevin Sharp's Avatar
Kevin Sharp
bara motorsport will do it, i remember when i was at bara,s heshowed me the stuff used in the viscous diffs..same stuff as im silicone implants he said, it was a clear gel.
talking about silicones did get me excited though
Old Feb 3, 2009 | 11:56 PM
Paul_RS's Avatar
Paul_RS
Kev
Just something i've wondered about, i'll drop Martoon a line sometime and see what he can do
I've never heard of anyone doing it over here either Stevie. Talked to Steve Gault about it a while back and he agreed.
Old Feb 4, 2009 | 03:58 PM
Mad Matt's Avatar
Mad Matt
Rally nut
The silicone is a special one used, like you cannot find anywhere in the shops. Tons of research has been put in these silicone gels, not a job for anyone. Bara Transmission is the company to ask for that job !
Old Feb 4, 2009 | 09:09 PM
marco polo's Avatar
marco polo
hi mate
bara has all the rights to VC (lock stock barrel) , he can uprate any VC mits/subaru/cossie/viper basically any car that uses a Viscous Coupling and it will be done right as he has a dyno to measure the right Nm's
obvisouly with the standard plates you can only uprate them so far
heres an example a 7.5" cossie rear V.C can be done to 240Nm no problem at all with the standard plates (25Nm standard when new)
lets say if you wanted a 300 -400Nm uprated VC then plates would have to be changed for the Nickel plates which can take alot more pressure/flex alot of people go this route on the rally cars lose surface
cheers marco
Old Feb 4, 2009 | 09:22 PM
DAN400's Avatar
DAN400
Originally Posted by Paul_RS
Kev
paul give fred crawford a bell, mate of mine got his done a few years back through fred , he ll put ye right one way or the other !
Old Feb 4, 2009 | 09:30 PM
Mike1's Avatar
Mike1
Originally Posted by marco polo
hi mate
cheers marco
Marco
What effect does the uprating of the diff have on a road car's behaviour - locks up more and hence more tail happy? Could you describe a little bit?
Old Feb 4, 2009 | 11:50 PM
marco polo's Avatar
marco polo
Originally Posted by Mike1
Marco
hi mate
it basically locks the other wheel nearly striaght away for better handling traction there is no down side at all on the road in a rd car
there few people on here have had there rear diff uprated and they cant belive how good it works
marco
Old Feb 5, 2009 | 08:07 AM
alistairolsen's Avatar
alistairolsen
can anyone give a ballpark cost for this?
Old Feb 6, 2009 | 12:59 PM
alistairolsen
bump, keeping standard plates, just to change the fluid and increase the rate slightly?
Old Feb 6, 2009 | 01:16 PM
robrs2's Avatar
robrs2
Have a look here http://www.gearboxman.co.uk/psdiffsgearboxman.html
£175 for uprated diff
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
