General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
you can still get them,the beam mounting plates,washers and the 4 bolts that hold the plates to the chassis new from ford for less than Ł25.i got all that and more 2 weeks ago.
I have heard they are hard to get the bolt in with the poly bush's and some people use slightly longer bolts to make it easier??
get the beam in place and put a jack under it to compress the bush,then screw the bolt in.ive done it a few times and never had any bother with the bolt.but thats 1 way to get it in place.thats the way to get the bush in aswell.
Ok cheers i wil try that. My friend has a press so i should be able to just press the bushs in if i take the beam out completely.
Have to add brake lines and shocks, springs and rear shims also anyway so back will be basically stripped anyway.
