frst battery light staying on?
Disconnect the IND wire, the thin blue one that goes to the charge light, if it goes out then the circuit is ok so feed is coming through the alt, the IND terminal on the alt is earth when stopped but turns live when running(rotating) so turning light out, seesm like it is not switching over, oddly enough it could still be charging!!.
Put a metre on now and see if it is outputting, but whatever it shows the alt would be at fault, if wire disconection puts light off.
The light warning bit is part of the regulator/rectifier pack, so a quick fix for lecky place.
Give it a good rev before above though as some need more of a kick to initiate.
155lee
06-09-2016 11:10 AM
The Enigma
12-09-2015 10:12 PM
