EGT thermocouple K-type - which one ?
Rally nut
I have a pectel monitor with input for exhaust gaz temp, and have to get a K-type sensor with I would say the extra wiring to connect it to the monitor plug.
Anyone got good address (ebay prefered) for sensor, gland, and extra wiring ?
Thanks in advance !
Thanks in advance !
Testing the future
don't forget that you cannot extend TC wiring with any other wire apart from the same wire that the TC is made of as you will have more disimilar metal junctions affecting the voltage generated
Still better to get long thermocouple though - buy some fibreglass insulated telflon coated k-wire and cut it to length.
Colossal Pervert
All of the wire, connectors, sensors and compression glands are available with screw terminals so it's nice and easy
I find farnell is quite good.. I was shown the light with a 150x3mm TC and stainless steel compression joints..
Rally nut
Thanks for the advices yet ! So TC diameter should be 3mm, but what about the length ? I will put it at the end of the 4wd exhaust manifold (near the turbo), so I think it shouldn't be very long. Found that one which may be good, but its 150mm long:
http://uk.farnell.com/labfacility/km...ple/dp/7078183
I will then need a correct extra 2 meters long lead to get to the pectel monitor inside the car.
Am I doing things right there ?
Testing the future
personally i would get one made from inconel that can withstand higher temperatures and as you say it doesn't need to be that long (although they often are).
shorter is better as you only need 50mm or so through the top of the gland (get stainless steel glands).
as you say, you will need a proper extension lead as the junction will be in the engine bay which is a different temperature to the car interior where the 'cold' junction is, and other cables would make an incorrect reading
Rally nut
Ok I guess they are marked at NiCr-Ni (nickel and chrome, and I know inconel is made mostly from nickel, but with magnesium, chrome and few other things), so these must be the ones I need.
http://www1.chf.conrad.com/fas6/fh.p...fview%3Dsearch
Thank you mate, gonna order that one have to find a "gland" now :P
Testing the future
i can't find them on the conrad.de site anymore
they used to sell some that could withstand 1250 deg. C, but it doesn't matter. if you have over 1100 then the thermocouple is the least of your worries
i think the NiCr-Ni is just the materials that make a k-type thermocouple junction
Rally nut
Just got 2 more questions :
Where on conrad's website do you find the green connector ? I need one to connect the extended wire to the pectel monitor EGT plug.
Also how do you make the junction between the std EGT sensor wires and the extension wires ? Do you "weld" (don't know the correct english word) or do you just put the wires into another plug ?
Help welcome !
Help welcome !
these are the best place for anything to do with egt senors etc
www.exhaustgas.com very helpful and very fast service and quality is unreal for a sensor heres the ones i brought
and they can make them any lenght
cheers paul
cheers paul
Testing the future
Help welcome !
Help welcome !
Rally nut
Well I think I'll order from the website richard told me.
Just want to be sure all the parts are correct before ordering them tho
http://www.tcdirect.co.uk/deptprod.asp?deptid=190/3
Thermocouple k-type, inconel 600, 3mm diameter, 150mm long with thermocouple plug
http://www.tcdirect.co.uk/deptprod.asp?deptid=280/3
Extension lead. I have a female connector on my pectel monitor, and there is a male connector at the end of the thermocouple sensor, so I have to take a female/male extension lead, does it mean I have to take a plug/socket one or ? My english isn't that good
http://www.tcdirect.co.uk/deptprod.asp?deptid=310/1
Also unsure about the compression fitting kit. I know I have to take stainless steel, but other than that, don't know which one would suit the thermocouple sensor.
Thank you very much lads !
Testing the future
I wouldn't go for one that has the plug connected to it like that as it is difficult to secure it without having problems with vibration
I would use one like this:
http://www.tcdirect.co.uk/deptprod.asp?deptid=190/1
405-0653.0mm dia x 150mm long
but that comes without plug, but not a problem to put one on (just remember that the green wire must go to the + side of the plug)
http://www.tcdirect.co.uk/deptprod.asp?deptid=280/5
724-320Type K Standard Plug
yes, you need a plug (male, to put into your female on your pectel monitor) to socket (female, to insert the male on the thermocouple into)
obviously it needs to be a 3mm one, and then the other size is the size of thread that you can cut into your exhaust. you need a tapered thread, which means that the hole gets sealed as you tighten the fitting into the hole and it gets wider
Rod-Tarry
237
18-03-2016 09:13 PM
automotive, compression, cut, ebay, egt, extend, fitting, ktype, probe, tc, thermocouple, thermocouplers, type, wire, wires
