Sierra 4x4 rear diff
Old 18-01-2009 | 11:21 AM
ybturbo's Avatar
ybturbo
Default Sierra 4x4 rear diff
Hi guys! Does anyone know what is the horsepower limit of the sierra(sapphire) cosworth 4x4 rear differential?
Old 18-01-2009 | 11:38 AM
Graceland's Avatar
Graceland
Team HOTHOT!
It's not the horsepower that kills the diff, its the torque, other than that, no idea
Old 18-01-2009 | 11:40 AM
The Youth.'s Avatar
The Youth.
dunno but 3rd gear goes first, I know that first hand!!
steve
Old 18-01-2009 | 11:47 AM
ybturbo's Avatar
ybturbo
Well I have 400bhp & 500nm of torque and I am planing to install stronger gear kit because I am repairing my gearbox quite (often and not only the third gear but also 2nd, 5th and input shaft gear!) thats why I am asking...
Old 18-01-2009 | 01:07 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
If I was in your position I'd try to get hold of a 7.5 inch diff, all you have to do to make it fit is chop 1 ear off of the beam and re-weld it back in (30 minute job).
Other alternative would be a complete 2wd saphire rear beam, just swap the 4x4 brakes and escos rollbar over to the saph rear beam and you're sorted. The ratios are 0.02 out so 100% safe to use in 4x4
Dan
Old 18-01-2009 | 05:54 PM
alistairolsen's Avatar
alistairolsen
has anyone broken one and at what stage?
Old 18-01-2009 | 05:58 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
it depends how the power comes in tbh, i broke 3 front diffs, 1 rear diff, and 3 gearboxes on a t34.48, at 370bhp 420lbft.
but bigger turbos are kinder to your drivetrain if you dont launch it,
Old 18-01-2009 | 06:43 PM
Renton's Avatar
Renton
They cost nothing to buy (well, £50-£100..?) and don't break as often as the gearboxes and drive shafts, so drive on driver!
Old 18-01-2009 | 07:42 PM
polly_x's Avatar
polly_x
I broke the one in my Westfield last year running somewhere between 400 and 450 horses. It had a lot of abuse over 4 years both on track and saw at least 50 full on Launch control starts. Ive no idea of its origins but assume it was just out of a normal 4x4 so would be about 15 years old too.
It broke on a launch with new sticky tyres.
Old 18-01-2009 | 07:51 PM
alistairolsen
Im looking at buying a limited slip one which is about 175 quid and then running 400bhp ish thru it in a locost. Stus experience leaves me with some hope tho!
Old 18-01-2009 | 08:00 PM
westus1's Avatar
westus1
not much weight in a locost
and if its only running 2wd it actualy takes less strain than 4wd cause it'll just spin the wheels
it should take that power for a while
if you can go for the 7.5" diff out a 2wd instead
they're stronger and you'll be able to pick 1 up no prob for the 175 you mentioned
Old 19-01-2009 | 10:00 AM
ybturbo's Avatar
ybturbo
Thank's a lot guys! It seems that the diff will hold since I don't do drag starts but again the weak link in my drivetrain is the gearbox because if I just plan the throttle down in any gear (except 4th and 1st) on full boost( 1.4bar) the gears will brake allways at 5000-6000rpm. So after installing stronger gears will see about rear diff.
Old 19-01-2009 | 10:09 AM
Renton's Avatar
Renton
They're LSD as standard aren't they?
You're welcome to pay me £175 for the one I have kicking around at my workshop if you want?!
Old 19-01-2009 | 12:22 PM
alistairolsen
yeah, 3.62 lsd as std. They seem to go for about that on ebay
Of yourse if you fancy giving me a bargain
Old 19-01-2009 | 12:40 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i broke 4,including 2 plated ones.
then i changed to a 7 1/2,plated diff.
i used a granada diff,available from ebay 30 to 50 quid.
Old 19-01-2009 | 04:06 PM
dom123's Avatar
dom123
what turbo you running mate?
Old 19-01-2009 | 04:11 PM
Renton's Avatar
Renton
Could your car's appetite for rear diffs have more to do with the strength of your Skyline gearbox, the amount of drive you're running to the rear wheels, or your launch technique than strength/weakness or otherwise of 4WD Cossie rear diffs?
Old 19-01-2009 | 04:28 PM
Lloyd's Avatar
Lloyd
you will allways break the weakest link,lol.
how long a 4wd diff lasts,has more to do with its condition,than the power you are running.ie 100k milage without any fresh oil and adjustment will break a lot sooner than a new diff,with fresh oil,and correct free play adjustment.
as a general guide,the planet gears normally fail around 450bhp,and the cwp at 500 bhp.
the 2wd is a lot bigger unit,so planet gears at 500 bhp, cwp at 550 bhp.
2 of my diffs broke under acceleration,one in 2nd gear and the other in 3rd gear.
as i said,just use a granada rear diff,same as the cos 7 1/2,just uses a different back plate. there are loads on ebay 50 quid ish .
Old 19-01-2009 | 04:59 PM
ECOS95's Avatar
ECOS95
Good to know what to expect from them.
Old 19-01-2009 | 07:14 PM
col cos1's Avatar
col cos1
does it have to be 24v cosworth diff?
just dont think other granadas will have lsd?
Old 19-01-2009 | 09:21 PM
ybturbo's Avatar
ybturbo
I am running stock turbine housing with a compressor from GT 38.
Old 19-01-2009 | 09:37 PM
westus1's Avatar
westus1
a lot of the 2.8' and 2.9's had slippers in them
dont know if its standard or option etc but seen plenty with them mate
Old 19-01-2009 | 09:59 PM
Lloyd's Avatar
Lloyd
check the link mate, full list of diffs and ratios.
http://www.locostbuilders.co.uk/view....php?tid=19116
Old 20-01-2009 | 09:24 PM
col cos1's Avatar
col cos1
i know the 4x4 will of had 7in like xr4x4 but never knew the2wd did,good to know that
Old 20-01-2009 | 10:14 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how good will a 4x4 diff be in a 3dr, fully stripped ect with around 400bhp max id guess?
the cunt off here who sold me genuine 3dr stuff, clearly neglected to mention that the rear beam and diff were 4x4...
my only spare is off the 1.6gl 4 speeder lol. taller geared tho, so may do 200mph in about 10 miles lol
but you need the push in shafts not bolt on jobbys.
lloyd, how do adjust them etc?
Old 21-01-2009 | 08:38 AM
Renton's Avatar
Renton
Isn't the 2WD a 7.5?
Old 21-01-2009 | 08:39 AM
Renton's Avatar
Renton
Your engine will never make over 400, so you should be fine with a 4WD diff
Old 21-01-2009 | 08:02 PM
col cos1's Avatar
col cos1
yeah 2wd is 7.1/2 i was talking about 4x4s
Old 21-01-2009 | 08:15 PM
Lloyd's Avatar
Lloyd
if you remove the back cover from the diff,the stub shafts are held in by c clips,
you can interchange the larger 2wd stubs and the smaller 4x4 stubs.
ie 7 1/2 inch diff with the smaller 4x4 shafts.
Old 21-01-2009 | 08:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
thats good to know then
is there anyway you can tighten the lsd up?
ie make it have as little slip as poss?
as most people you see in a 2wd cos trying to do a burnout just light up the 1 wheel usually lol
renton - coont
Roosie
11
22-08-2015 10:13 PM
Vincereese
15-08-2015 06:24 PM
Vincereese
11-08-2015 08:44 AM
xr4x4rs
06-08-2015 09:03 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Sierra 4x4 rear diff
