Gaz Coilover problems.
Old Jan 10, 2009 | 10:14 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Gaz Coilover problems.
I'm not usually one for putting a similar post in 2 sections, but I'm having problems with my Gaz Gold Coilovers and it's chewing away at me, so wanted to see if anyone has had any similar experience?
I actually bought these over a year ago, but have only just fitted them.
Originally Posted by Christian and Beccy
I've fitted my Gaz Coilvers, after overcoming the issue's with the front bearing/top mount and so on. I have set the ride-height approximately, if anything it is on the low side, but until it's all back together, I don't want to set the height properly, but one thing is for sure, it will be going UP not DOWN.
However, when you bounce the rear of the car it knocks like fuck.
Gary reckons it's because the rear shocks are effectively 'topping out', so they are too short. Lowering the car more would possibly solve it, but I don't want it lower, I want it higher!! I'm looking for the height I had it before, so the equivalent of around 30mm lower than standard.
Anyone else had such problems?
Old Jan 10, 2009 | 10:19 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
like the actual shock is too short? i thought you could run them at -30mm ok...weird
where abouts is the platform set? at the top?
Old Jan 10, 2009 | 10:33 AM
Christian and Beccy
#1 in Spelling Club
When I first fitted them, the car was far too low, so I wound the platforms up and it got harder and harder as though the shocks were topped out and I was compressing the spring.
To go any higher would put the spring under even more tension.
Old Jan 10, 2009 | 10:35 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Have you actually jacked the car up and measured the droop?
Old Jan 10, 2009 | 10:36 AM
Eagle's Avatar
Eagle
Super Moderator
shorter springs??
Old Jan 10, 2009 | 10:43 AM
Christian and Beccy
#1 in Spelling Club
Next to fuck all, but I haven't measured it. Like most people, I thought that buying a set of coilovers that are supposedly correct for the application, they would be practically bolt-on with no agro.
Old Jan 10, 2009 | 10:44 AM
Christian and Beccy
#1 in Spelling Club
Originally Posted by Eagle
shorter springs??
That wouldn't help, would it? It's the open length of the shock that looks to be the issue??
Old Jan 10, 2009 | 10:50 AM
costina's Avatar
costina
Live long and prosper!!
Have u modded the left rear inner arch??
they allways knock on that sidethe spring hits the inner arch which needs dressing back with a large ball pain hammer
Paul
also with the low ride it will not knock due to shock angle
Old Jan 10, 2009 | 10:55 AM
JTECH James
Passion for Fords!
my springs go tight when i take the platfom over half way, as you say the shock piston doesnt go high enough, but if you keep raising the platform putting the spring under tension, the car wont compress the spring as much when the weight is on it... and you do get higher ride height, i can make mine look like an offroader
its probably knocking because you dont have enough tension on the spring, as the spring will jump about if its near its full length
its how they work, its kind of backwards to a std strut, on coilovers you push the spring up to tension it, which pushes the piston to its stop...without that you wouldnt be able to tension the spring...
Old Jan 10, 2009 | 11:06 AM
rstdave's Avatar
rstdave
Christian: have a look at my reply in the rs turbo section mate!
Old Jan 10, 2009 | 11:12 AM
simon170's Avatar
simon170
Maybe Gaz need to make a longer shock if those ones are "topping out" when the suspension rebounds. Should give you room to raise the cars ride height when finished.
My 2p's worth.
Old Jan 10, 2009 | 11:16 AM
JTECH James
Passion for Fords!
My 2p's worth.
they are meant to top out...how else would you tension the spring? if the piston doesnt stop so you can wind the platform up making the spring tight it simply wouldnt work. plus the fact springs loose is an mot failure iirc
its how they work
topping out is normal, there is no real weight behind it, just the spring tension, it wont make any noises....
unlike bottoming out, which has the weight of the car behind it...
Old Jan 10, 2009 | 11:28 AM
simon170's Avatar
simon170
JTECH - I know they must top out mate, too keep the spring under control, but it sounds like they are doing it a little too early (even with Christian just bouncing the car by hand). So maybe slightly more shock travel would help. Plus your could wind up the platform to get the extra ride height Christian wants.
p.s Good luck with your 180mph attempt
Old Jan 10, 2009 | 11:35 AM
JTECH James
Passion for Fords!
thanks mate
i reckon its noisey because there isnt ENOUGH tension on the spring,the platform needs raising more.
Old Jan 10, 2009 | 11:36 AM
rstdave's Avatar
rstdave
The gaz oilovers certanly ain't quiet when topping out.......plus as said they shouldn't top out under normal driving conditions! The springs being loose depends on the height adjustment you make but you can fit helper springs if required to overcome the problem of the spring being loose when the car's jacked up.
Old Jan 10, 2009 | 11:39 AM
JTECH James
Passion for Fords!
mine are silent, and as any coilover they run topped out all the time....when the weight is off them
if your spring is loose when jacked up, imo thats your noise, not the shock
simon170's Avatar
simon170
You reckon the springs is expanding fully and going loose between the topmount and adjustable collar, yeah? Certainly would clunk loudly...
Old Jan 10, 2009 | 11:44 AM
rstdave's Avatar
rstdave
How can they run topped out all the time?? If that was the case the suspension would have to be solid?! When there's weight on the shocks and the springs compress the shock leg moves down too so i can't see them being topped out all the time! And yours may be silent but if they're not gaz golds on an rst then it's not really a direct comparison.
Old Jan 10, 2009 | 11:45 AM
pee vee's Avatar
pee vee
I found the Gaz shocks top out with a CLUNK if you run the damping on some of the softest settings (first 4-5 clicks).. sadly their cheap-ness shows.
Old Jan 10, 2009 | 11:46 AM
JTECH James
Passion for Fords!
when the weight is off them, the piston is topped out.....it must be as my spring is tight....and you cant get a tight spring(jacked up) without topping the piston
Old Jan 10, 2009 | 11:48 AM
rstdave's Avatar
rstdave
They must be bloody heavy springs lol!
Old Jan 10, 2009 | 11:51 AM
JTECH James
Passion for Fords!
explain how you tension a spring then, what does the spring push against? when jacked up...even with helpers fitted
Old Jan 10, 2009 | 11:52 AM
Christian and Beccy
#1 in Spelling Club
Well, how its set at the moment there is approximately an inch between the wheel and the arch and if you jack the car up, thats where it stays. There is no droop whatsoever, that can't be right, can it?
Old Jan 10, 2009 | 11:53 AM
pee vee's Avatar
pee vee
no, they are too short.. are you running standard rear turrets Christian? or have they been modded/strengthened?
Old Jan 10, 2009 | 11:55 AM
Christian and Beccy
#1 in Spelling Club
Fully seam welded turrets, but other than that, standard.
When I bought them, Gaz said I should run a decent rear brace or better still seam weld the turrets, I did both.
simon170's Avatar
simon170
On full extent its an from the arch?
I'd ask Gaz about adding some travel to them.
Old Jan 10, 2009 | 11:58 AM
JTECH James
Passion for Fords!
that is odd, i give up lol
Old Jan 10, 2009 | 12:00 PM
Christian and Beccy
#1 in Spelling Club
But if what you're saying is right and the you tension the spring up against the top-stop, then how is it going to have any droop? The shock is at its full extent.
Old Jan 10, 2009 | 12:06 PM
JTECH James
Passion for Fords!
you deffo have to tension the spring, and you can only do that by tightening the spring between the platform and the top seat(piston top) you can only do that if the piston stops extending. but thats weight off at full travel .
think about it, if the piston didnt stop to allow you to wind the spring tight, every time you jack it up the spring will be loose lol.
but when the weight is on the car, it should give you travel as the suspension compresses and droop when you jack it up.... back to the full travel
what poundage springs are they?
Old Jan 10, 2009 | 12:25 PM
costina's Avatar
costina
wrong car sorry hav'nt woke up yet
hope u sort it
Paul
Old Jan 10, 2009 | 01:46 PM
Tim's Avatar
Tim
imo you need to raise the ride hight yes in effect putting more tension on the spring what is happenenig from what we found is the cup on top of the gaz shock top (assuming you refitted the inner cup from on top the old shockers) is pattering as you bounce on the car ie becoming loose the tight i know it sounds hard tp accept as you tension the springs up as the wheel is suspended but the shocker is dampening the effect when its on the floor ,anyways your cars to low raise it and the problem will dissappear.
best way to adjust the springs throw the c spanner in the bin and use an oil filter tool ie the big clamps to turn the seat easy as.
p.s what rears spring rates you got the standard are pants you need at least 220lbs,better not say anymore or u will be pushin me round the track pmsl
Tim
Old Jan 10, 2009 | 01:49 PM
Rossco's Avatar
Rossco
The guy who runs the machine shop a few doors up from mine has found the same with his Gaz legs on his red topped Corsa, he worked all the spring rattings and damper travel out and decided that the Gaz stuff was miles out. He ended up specing some springs and having some dampers made, dont think they are fitted yet.
Old Jan 10, 2009 | 03:10 PM
pee vee's Avatar
pee vee
yes this happens a lot.
when you jack the car up, more often than not, you get 'helper' springs to fill the gap, where the main coilover spring goes loose.
where the piston out-extends the coil spring.
Old Jan 10, 2009 | 03:25 PM
Christian and Beccy
#1 in Spelling Club
Tim,
We did look at spring rates a few weeks ago, because I ordered these so long ago that I can't remember what I ordered. I've since forgotten what they are!! PMSL. I'm sure they are around 250lb. If they are coming off again, I can check again and will remember to write it down. The joys of being old eh??!!
I can't see how having NO droop is right. I hear what you are saying, but I think I will speak to Gaz on Monday and see what they suggest.
Old Jan 10, 2009 | 03:38 PM
155lee's Avatar
155lee
when i jack mine up the platforms on top go out of line,you have to lower it with your hand in the arch guiding the spring and cup back into the right place,if you dont do this they knok like mad,mine are only 11 months and 1000 miles dry old and they are really corroded,im going to call gaz on monday to get them re-coated.
Old Jan 10, 2009 | 03:42 PM
Rick's Avatar
Rick
If it's got no droop, the piston must be fully extended. You used to be able to get short shocks, sure they aren't those?
Old Jan 10, 2009 | 03:45 PM
cossiecrew's Avatar
cossiecrew
we fitted gaz coilys on beachs saph the comps caught the spring cup unlinke the avo so straight away he had to lay out on shorter springs and if im honest they were the most squeaky leaky pile of bollox i have ever come accross
Old Jan 10, 2009 | 04:31 PM
JTECH James
Passion for Fords!
yes, but if the piston doesnt hit the stop, even with a helper it will still be slack....the piston has to stop or you cannot tension the spring...length of the spring is irrelevant tbh..because you need to tension it somehow
so the piston will hit the stop everytime the weight is off it... otherwiise you cant make the spring tight...
if you have short springs that dont push the shock to its stop, you fit helpers, which keep the piston at full travel on the stop when the weight is off
Old Jan 10, 2009 | 06:58 PM
Christian and Beccy
#1 in Spelling Club
It's all irrelevant isn't it? If the shocks have no 'droop' then they are wrong, aren't they? Simple as. It is not uncommon for springs to be loose when the car is drooped, but of course this 'slack' is taken up once you put the weight on them.
I am kinda happy with the height of the car, would prefer it a little higher, but if I jack it up, 2 pumps on the trolley jack and the wheel is off the ground.
Old Jan 10, 2009 | 07:03 PM
JTECH James
Passion for Fords!
mine doesnt droop so the spring is loose, or any of the ones ive fitted...
