electronics question
Old Jan 8, 2009 | 08:58 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default electronics question
it's been abotu 20 years or so since i've needed to know what was what and why they are called what they are called, so this morning i've got some questions to prepare me for the weekends activities
led's
what are the 2 legs called?
and which one is the positive? the longer one right?
resistors
which way do they flow? towards the single line right?
i know i could google the answers but i'm crap at that and none of the sites i've looked at have given me the answers i'm after
so thanks kind chaps and chapesses for answering
Old Jan 8, 2009 | 09:16 AM
LED, have ANODE and CATHODE
ANODE = POSITIVE, CATHODE = NEGATIVE.
Resistors ?, I assume from single line you mean RECTIFIER DIODES ?, if so the line depends on which way you want current to flow/not flow.
If flows easy through the line nearest but not the other way.
Resistor orientation is unimportant as they don't have one, they work either way.
Old Jan 8, 2009 | 09:22 AM
Mike Kerbey's Avatar
Mike Kerbey
resistors flow both ways, so no polarity. The Single line is normally gold, which shows the tolerance of the resistor value. There are other colours but ive forgotten them lol
Old Jan 8, 2009 | 09:23 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The 'single line' as you call it on a resistor is the tolerance value, 5%, 10% etc.
Old Jan 8, 2009 | 09:25 AM
Mike Kerbey
and on the led the longer leg is the anode
Old Jan 8, 2009 | 09:46 AM
biglee's Avatar
biglee
Audio specialist
if you look into the LED one leg will be connected to a much larger plate inside the actuall led, this is the cathode so the larger plate is the negative and the tiny plate is the positive,
thats how you find out if the legs have been trimmed down.
Old Jan 8, 2009 | 09:48 AM
biglee's Avatar
biglee
Audio specialist
yes indicated by a silver or gold band depending on the tolerance of that particular component. silver is 10% and gold is 5% usually.
Old Jan 8, 2009 | 10:05 AM
dojj's Avatar
dojj
yup, longer ones are connected to the smaller plate so that's fairly easy for the led's
the resistors thoguh:
they've got 5 lines on them, 4 do the vaule if i can remember that far back and the other line should be gold silver of bronze to tell you somethign else corect?
these don't though
they've got a red line, then a gap, then 2 black lines, a grey line and another red line grouped together
they shuold be 270ohms
but which waydo i solder them?
Old Jan 8, 2009 | 10:12 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
As above, any way you like!
Old Jan 8, 2009 | 10:14 AM
dojj's Avatar
dojj
i've got a drawing drawn up to tell me what i need to do then
thanks all who participated in this helpfull post
Old Jan 8, 2009 | 10:27 AM
biglee's Avatar
biglee
Audio specialist
red grey black, then the multiplyer line. then the tolerance.
270+0 and a 2% tolerence. solder them any which way you like
Old Jan 8, 2009 | 10:43 AM
RichieST's Avatar
RichieST
Yup they can go any way round, however when I was doing electronics at college I was always taught to mount them the same way round as each other, just makes the job look a bit neater!
Old Jan 8, 2009 | 10:50 AM
FlatheadFordV8's Avatar
FlatheadFordV8
http://www.csgnetwork.com/resistcolcalc.html
try this for resistors
Old Jan 8, 2009 | 11:11 AM
ECU Monitor Enthusiast
dojj,
Whilst I appreciate not everyone understands these things....
The thought of a directional resistor just made me spit my tea over my keyboard
Old Jan 8, 2009 | 11:20 AM
dojj's Avatar
dojj
maybe i'm thinking of something else then
it's been the thick end of 20 years since i had to do this thing for a living
Old Jan 8, 2009 | 11:28 AM
lead_foot's Avatar
lead_foot
is awesome
Thinking of a diode?
Old Jan 8, 2009 | 12:42 PM
dojj's Avatar
dojj
pissibly, although that's probably soethin else i'veforgotten about in the course of the years
i've got a b/tec certificate somewhere, with a pass rate of over 85%, in electronics, i shouldn't be forgetting this stuff, should i?
Old Jan 8, 2009 | 01:26 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No, not really..
Old Jan 8, 2009 | 01:35 PM
RichieST's Avatar
RichieST
A btec? Fuck me i got a btec at college for having the highest attendance rate in the class I knew fuck all about the subject
Old Jan 8, 2009 | 03:08 PM
Eagle's Avatar
Eagle
Super Moderator
i got a c&g 224 ... but cant remember a single thing
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
