Soldering (ARRRRRRRGH)
PassionFORD Member
I've got a electric RC car because I fancies one over nitro and I'm trying to solder the wires to the motor. I've done the positive one fine but the negative...I won't even use words to describe it, these can do it for me:ang ry:
I know what the problem is, it's the SHIT surface I have to solder onto and the solder won't take to it I've cleaned it about 6 times and have chopped off about 2cm of wire as well just re-trying to solder and fuck knows how much solder as well! I'm using Deans racing pro-flux solder so I know it isn't my solder. ARRRRRRRGH! No mater how many times I clean the fucking thing the solder just won't take! I give up
I don't see any solution here if I can't get the solder to take.
PassionFORD Member
I would take it mate, mine are excellent and I know them well but I ain't letting fucking soldering get the better of me!!! If it was something difficult I'd concede but don't want to concede soldering a wire to a motor
piece of piss soldering, hee hee... as i do it eveyday, like loads...
The problem with the V2 motor is the alloy heatsink on the end, so it takes a real manly iron to heat them up. Personally I've always soldered a 2" piece of wire to the motor with my big iron in the house, then its just a case of soldering two wires together when I'm at racing, which doesnt require so much heat.
PassionFORD Member
Will try tabetha's advice. If that don't work, the hobby shop can deal with it
Only thing with V2 endbells, you can't use connectors or clips (that I know of), you HAVE to solder straight on.
Resident Wrestling Legend
put the motor in a vice
put the iron on the underneath of the connection
clamp the wire on the top, pressing down with the solder on the other side of the clamp
once the connector is hot enough, the solder will melt onto everything, all you need to do is remove the clamp then
hard to describe but if i had a picture i'd show you what i meant
PassionFORD Member
I know exactly what you mean Dojj, only two problems:
1) I don't have a vice
2) There is absolutely no chance in hell I can get the iron even with a bullet tip underneath the connector
Had plenty of expierence soldering these bastards
Just get the biggest hottest iron you can find and it will go on without any trouble.. no need to roughen up the surface really either from expierence
PassionFORD Member
I'm using a gas powered iron. It is having no trouble melting solder but because the cables are thick if I touch one end, it doesn't carry enough heat to melt solder on the other side of it. Anyway, I've conceded. The piss take is the other side was so easy to do! It was taunting me in the end, I could physically melt the solder and touch the wire onto it and push it onto the surface and it would solidify then when I took my hands off, off it came!!! and you could see the solder had melted to the shape of the surface but just won't stick!
just sounds like the iron isnt up to the job mate, i solder every day, pcbs, wires connectors etc, just sounds like a beefier iron is needed...not funny tho when things like that happen..
PassionFORD Member
I hope it's just my iron mate, I really do cos if it ain't it means the endbell is scrap! I know my LHS use an 80W or 100W depending on what they need to solder so I'm hoping that they can do it!
me old mate 10th_racer on here used to be able to solder these in about 10 seconds..
100w iron with a big fat tip on it is the way to go for soldering these.. easy as pie.. or you could get just a brushless motor, one extra tab to solder but so so much easier. I manage just fine with a 45w iron
