Power Required
Old 06-01-2009, 04:44 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Default Power Required
What power do you need to get a 120mph terminal speed on the 1/4 mile.
The car is my 4i. Full road trim, standard cossie diff and box with 205/40/17 tyres, must be the same weight as a 3dr cossie.
Steve.
Old 06-01-2009, 04:46 PM
costina
Live long and prosper!!
costina's Avatar
Steve.
25bhp more than u got
Paul
Old 06-01-2009, 04:49 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Paul
At least mine uses more petrol than oil
Steve.
Old 06-01-2009, 04:54 PM
costina
costina's Avatar
Steve.
lol yours should be a bit lighter than a std cossie you have'nt got abs have you??
Paul
Old 06-01-2009, 08:26 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Paul
I think my 19stone mass and the 330mm discs and king size calipers might make up the difference
Steve.
Old 06-01-2009, 08:31 PM
mechanic28
mechanic28's Avatar
you diff will be left behind at the start line!specially without a decent mount!
Old 06-01-2009, 08:35 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Big turbo time stevie boy.
Steve
Old 06-01-2009, 08:37 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
At least i have the balls to use mine Doug
Steve.
Old 06-01-2009, 08:38 PM
Kevin Sharp
Kevin Sharp's Avatar
you will need around 500bhp to see that sort of terminal
mechanic28
mechanic28's Avatar
Steve.
mine as a few problems at the mo
Old 06-01-2009, 08:40 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
No bloody hope then
Steve.
Old 06-01-2009, 08:42 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Steve
No more engine mods until it dies now.
Steve.
Old 06-01-2009, 08:43 PM
mechanic28
mechanic28's Avatar
Its all in the launch and the first 60ft get that right and you get good times
Old 06-01-2009, 08:46 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
My 60ft time is crap @ 2.361sec
I have fitted rear shims and new tyres and it grips a lot better now, hope my 60ft time improves.
Steve.
Old 06-01-2009, 08:47 PM
Moonstone Steve.
You should see some gain now you have your special remap
Steve
Old 06-01-2009, 08:48 PM
Danny B
Danny B's Avatar
i ran 117's with 350ish, Crap 60fts will benefit if you only after a high speed.
Old 06-01-2009, 08:55 PM
mechanic28
mechanic28's Avatar
just think top fuel dragsters are doing over 100mph in that 60ft
Old 06-01-2009, 08:58 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I want to impove both my times and terminal speed.
Surely if you have a better 60ft your terminal will be faster as you have more distance to accelerate ?
Steve.
Old 06-01-2009, 09:00 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Steve
I would hope that helps as well due to the car holding 4psi more boost @ 6000rpm
Steve.
Old 06-01-2009, 10:25 PM
westus1
westus1's Avatar
my old saph used to cross the line around 120ish
escos wheels with 215/40/16,s, full interior/weight etc
proper full on, gearbox and diff killing launches every time
was just under 420bhp(cant remeber exact but was high teens)
oh yeah 4x4 if you hadn't already guessed
Old 06-01-2009, 10:42 PM
xr4x4rs
xr4x4rs's Avatar
a decent rear beam mate
Old 07-01-2009, 02:43 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
That dosen't answer the question
Steve.
Old 07-01-2009, 03:38 PM
costina
costina's Avatar
Get a pair of 15" cossie rims with R888's on
job donegrip is the key
Paul
wowk
30-03-2021 07:49 PM
20/20 vision
29-09-2015 09:25 PM
Quick Reply: Power Required
