will saffy clocks fit in2 a rst!?
I am wonderin if the whole of a 3dr or saff set of clocks inc the surround etc. will fit in2 a mk4 escort!?
any1 ever done it!?
any1 ever done it!?
but that clock panel was designed in the early 80s and it shows its age... you could get a nice lokin aftermarket panel with a clock on it
anyway the AWS stuff wouldn't work on it anyway (unless you went very trick and copied all that over from a sierra!) but then again, its not THAT usefull... lol
Jimbo!
the new mk4 will have a cossie enigne & managment gear box etc. etc.!
so i would like some hire speed clocks! also a rev counter that will work sstriaght with the cossie managemnt!
also ma temp sendor & fuel sendor that will plug straight up would be nice!
plus the mk4 dash aint really much newer than a saff!
plus if they will fit i will just use 3dr clocks which r kool & have a boost gauge in them! as this car will only have the stnadrd clocks & a secs monitor no other gauges!
I am wonderin if the whle of a 3dr or saff clock inc the surround etc. will fit in2 a mk4 escort!?
you mean the clocks
Team HOTHOT!
pretty much so yep - only thing that i needed to finish them off was a bit of fibreglass, but i mullered the rst engine i put in there - oops so scrapped the car
Maybe @ 1 point Brom!
Not yet though need to get the fooka built b4 i start buyin bling shit!
out of a matter of interest did u go down scottys!?
focus rs 1672
i put these ones in mine from a 4x4 saff just the speedo but but u need to shave a bit off for it to sit flush with surround,they do read a bit out but not much as all speedos overread anyway
just need the white dials out and im sorted
