Outlook Problem
Old Jan 5, 2009 | 08:43 AM
Mike C's Avatar
Mike C
The Special One
Default Outlook Problem
I keep getting an error message come up when I try and open Outlook (Microsoft Office Outlook 2007 I think it is).
It says:
"Cannot open your default e-mail folders. The file C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Outlook\Outlook.pst is not a personal folders file"
Google brings up plenty of articles regarding the solution, which involves going into control panel and then onto the "Mail" icon. One problem though. I do not have a "Mail" icon on my Control Panel!
So now where do I go?
Old Jan 5, 2009 | 09:36 AM
dojj's Avatar
dojj
Resident Wrestling Legend
is it located on an outside server?
i've had this problem loads of times at work and it gives you the option to open outlook in default mode or something
back up the files first thoguh ebfore you start messing with stuff i don't know about
Old Jan 5, 2009 | 09:55 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
MS outlook stores messages, calendar events, schedules and other objects in the PST (Personal Storage Table) file. .pst is the data file format used by it. This is Personal Storage File which retain all the data of this e-mail client.
The error messages, indicative of corruption, can shake the mind of user. One of such error messages is stated below:
“Unable to open your default email folders. The file D:…path to file…Outlook.pst is not a personal folders file”
After you click on the ‘OK’ button of this error message, the application will shut down.
This is the case when your PST has got corrupted and needs PST repair. MS outlook avails you the inbuilt utility, scanpst.exe, for this part which resolves many of the PST corruption issues.
You can find out more about this tool at the following URL :
http://support.microsoft.com/default...b;en-us;287497
Good old Microsoft rather than fix the issue they provide a tool to recover your screwed data
Remember to backup your data before screwing with it more than Microsoft have
Old Jan 5, 2009 | 09:58 AM
Turbocabbie
Top Cab !!
C: prompt suggests that it is the Windows drive on the local machine
Old Jan 5, 2009 | 09:59 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Better than not providing a utility.. or having to wait 12 months for some lazy coffee-drinky greasy-haired open sores monkey to fix the shit they broke.
Old Jan 5, 2009 | 10:28 AM
collierm's Avatar
collierm
MP for K.I.S.S
You'll also hit this issue if the PST file is approaching 2GB in size. Outlook can't open files above this limit.
I'd suggest check the file size of the PST, if its under this size, then run scanpst see if it helps.
If the Mail icon is missing and your running Vista, make sure you are running in Classic view and then the icon should display. If your running a 64bit OS then you need to enable the 32 bit control panel using Additional Options->View x86 Control Panel menu.
From the mail icon, you can configure the PST's you wish to open (if you have to create a new one).
Regards
Matt
Old Jan 5, 2009 | 10:51 AM
dojj's Avatar
dojj
the only thing i have learnt from reading this post is that i'll leave it to the professionals
but that may explain also why the computer goes into bonkers mode when my mailbox goes beyond 32 mb as set by the company
Old Jan 5, 2009 | 11:07 AM
collierm's Avatar
collierm
MP for K.I.S.S
That'll be a quota limit imposed by your sys admins.
Old Jan 5, 2009 | 11:09 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
had this problem for months!!cured tht one,now it says
"unable to start processing services,could not open item,try again"
Old Jan 5, 2009 | 03:10 PM
Turbocabbie
Top Cab !!
Do you mind, my hair is not greasy.
Old Jan 5, 2009 | 03:18 PM
Jim Galbally's Avatar
Jim Galbally
turbocabbie has the aswer there :Top:
also the 2GB limit dpoes not apply to office2007 as it uses the later format for PST files. i doubt very much hes using a PST created in o2k
Old Jan 5, 2009 | 03:19 PM
Mike C's Avatar
Mike C
The Special One
I'll give that a try, cheers for the response
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
