Toad AI606 lock from outside while engine running?
Old Jan 4, 2009 | 02:05 PM
BM08's Avatar
BM08
Default Toad AI606 lock from outside while engine running?
Is this possible?
Ive got two fobs so would it lock using my second one?
I could just try it yes, but im being lazy
Old Jan 4, 2009 | 02:10 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
A toad alarm will lock the doors if it is started with all the doors closed, but if the car is started with one or more doors open it wont automatically lock the doors when they are shut.
It senses that a door is open when starting and disables the auto locking function.
Old Jan 4, 2009 | 02:11 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
i dont think it will because if you press the lock botton it will turn the imbolioser on
Old Jan 4, 2009 | 02:14 PM
BM08's Avatar
BM08
yeah so you dont lock yourself out, but ive got another fob so i wonder what will happen if i start it shut the door and press lock...........
BM08's Avatar
BM08
I guess theres one way to find out
Old Jan 4, 2009 | 02:15 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Just re-read the question! I think I understood it wrong!!!
I wouldnt have thought the remote locking would work with the engine running tbh.
Old Jan 4, 2009 | 02:17 PM
BM08's Avatar
BM08
Ill give it a go if nobody knows for certain, it was just a question and a thought thats all
Old Jan 4, 2009 | 02:18 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
If you dont try, you wont know!
Old Jan 4, 2009 | 03:03 PM
gus's Avatar
gus
let me know cos it would keep it secure while it defrosts
Old Jan 4, 2009 | 03:04 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
i would have tryed it but my car dosent start
Old Jan 4, 2009 | 03:06 PM
Madbradz's Avatar
Madbradz
I start my MG ZT then lock it with the spare key... So its running and locked so it can defrost and warm up!
Old Jan 4, 2009 | 03:08 PM
xr4x4rs's Avatar
xr4x4rs
yes it will
as i used to mess around with mine when driving along lol
just try it, sit in the car with it running and press the spare fob, if it unlocks and locks job done
i know mine did
Old Jan 4, 2009 | 03:09 PM
becca s2rs's Avatar
becca s2rs
If you press the lock button with the doors closed engine running it just locks the doors, have never tried it with second remote but think it will be the same, also unlocks with the engine running. does anybody know how to turn off the auto lock as its a pain in the arse in my opinion
Old Jan 4, 2009 | 03:29 PM
BM08's Avatar
BM08
I think its good, could stop you from getting hi jacked or stabbed to death
Old Jan 4, 2009 | 03:50 PM
Thrush's Avatar
Thrush
Irritating c........
Once again you've managed to create a thread and drag something out for an hour and a half that would have taken you 30 seconds to find out on your own
Have a fucking medal!
Old Jan 4, 2009 | 03:56 PM
pani_k's Avatar
pani_k
PassionFORD Member
I wouldn't fuck about with it tbh mate. I've got remote start and all sorts going on in mine so I generally don't like to fuck about with it. The other day I was doing a dash diagnostic and because I turned ignition on and off 3 times it went into emergency override mode . I've never tried it but with the KOER, if you press the lock button on the remote it should lock the doors *I think* but if you've unlocked and un immobilized with one fob (primary one) it might not like the fact you are trying to use the second fob with the engine running and ignition on. You might get yourself into all sorts of shit.
Old Jan 4, 2009 | 04:03 PM
BM08's Avatar
BM08
Thanks for that, i wont try, knowing my luck ill fuck it up
Old Jan 4, 2009 | 04:54 PM
XRdodgybird's Avatar
XRdodgybird
Praise the XR!
It doesn't naff it up at all.... we do it all the time.... if you are that bothered, just take the fob off the keys..... get in it, start the car and get out.... 20 seconds later you'll be locked out of the car anyway LOL
Old Jan 4, 2009 | 05:05 PM
pani_k's Avatar
pani_k
PassionFORD Member
That's using the same fob though, not the second fob.
Old Jan 4, 2009 | 05:12 PM
XRdodgybird
Praise the XR!
they should both be programmed the same, we have two vehicles both with AI606's on and they are on different frequencies....
Old Jan 4, 2009 | 05:20 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Using the secong fob to lock/unlock works ok - I used to do it with my truck on a cold morning - start it, shift it to where I needed it, lock it with spare fob, enjoy coffee, unlock with spare fob, goto work
Old Jan 4, 2009 | 05:22 PM
The door lock works whether the engine is running or not, if doors are open it will attempt to lock, and sense one lock has not engaged, depending on type of lock(some will) cossies's wont and then immediately unlock.
So yes start with one fob on keys lock with another.
There is a possibility of AUTOLOCK even when a door HAS been opened, thius is due to dirty contact switches, ie it doesn't sense a door has been opened so you start car open door to get out 10 seconds after starting autolock kicks in, so make sure none of the door switches are ropey.
The autolock can be disabled by going through the KEY positions with the FOUR digit code you got with the alarm.
You can also enable or disable the BEEP on arm/disarm or alter the beep volume to one of 3 levels, but even quiet level is loud.
They should come with beep on arm/disarm disabled as it is illegal in rest of europe due to noise pollution.
Old Jan 4, 2009 | 05:28 PM
XRdodgybird
Praise the XR!
Rather it autolock than not. Let's face it, would you leave your car on your drive with the keys in it running and leave it? Not in this country......
At least as well with the perimeter sensor, I immediately know when someone is either stood at the side of it or passing it on my driveway.
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Zoggon
Aug 10, 2015 10:39 AM
Red_bull
Aug 9, 2015 08:34 AM
