car squealing problem!!
Old Jan 4, 2009 | 11:49 AM
Gaz 88's Avatar
Gaz 88
Default car squealing problem!!
the car is a focus rs and i was driving yesterday and the car was alright and i have come to get it out the garage and started it up to day and there is a squealing/winding coming from the left side of the engine bay (where the belts are) and when you rev the car the squealing gets louder? i only drove it out the garage but it seemed to stop when the car was in gear driving? any ideas?
cheers
Old Jan 4, 2009 | 11:50 AM
Frogford's Avatar
Frogford
cheers
Mouse infestation in the Garage and have got into the engine bay overnight ? Little buggers get everywhere !
HTH
Old Jan 4, 2009 | 11:58 AM
bassboy's Avatar
bassboy
belts are slipping by the sound of it...could be due to cold weather or they could be loose...maybe need replacing...next time it happens...try spraying a little wd40 on them and see if it stops it
bassboy
Old Jan 4, 2009 | 12:04 PM
Gaz 88's Avatar
Gaz 88
bassboy
cheers mate it seems to do it all the time tho?
Old Jan 4, 2009 | 01:54 PM
Robs Frst's Avatar
Robs Frst
your best bet would be to change the belt.
Im having this issue with my Zetec S
Old Jan 4, 2009 | 01:58 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
I wouldn't spray wd40 on them, it'll only make them slip more. If you get some proper belt dressing and spray that on with it running it should stop it. But ultimately you're gonna need a new belt and probably a tensioner.
Old Jan 4, 2009 | 05:59 PM
Try either talcum powder first on the belt underside ie the ribbed bit, this will stop it.
Old Jan 4, 2009 | 06:10 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
I once had this problem. I had no antifreeze in the engine and it was frozen solid. Lasted 30 seconds before it threw the cambelt!
Old Jan 4, 2009 | 09:03 PM
BRIGSPORT's Avatar
BRIGSPORT
It was only a cavalier sri mk2, my first car. My neighbours bmw did the same but he switched his off in time!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
