Sky+
Old Dec 30, 2008 | 05:41 PM
slim20012's Avatar
slim20012
Default Sky+
just a blue screen saying Searching for listings please wait has been working fine till now
oh and im only using it in the dinning room for a decent picture so we have no package or foneline connected could this be the problem ?
Old Dec 30, 2008 | 05:59 PM
SO COSSIE's Avatar
SO COSSIE
Take the power lead out of the back leave it off for about 2 mins then turn it all back on thats all mine need now and then just like a reboot.
Hope that sorts it
Old Dec 30, 2008 | 06:21 PM
slim20012's Avatar
slim20012
nope tryed that well lead was out for bout 3 hours but iv plugged it back it and re-set the box but still same thing
thanx's anyway
anymore for anymore ?
Old Dec 30, 2008 | 06:26 PM
vikingboy's Avatar
vikingboy
snow on LNB (dish?) or its fooked
Old Dec 30, 2008 | 06:38 PM
SHANE159's Avatar
SHANE159
Mines been same allday mate, so its down to them and not a fault on your end!!!
Old Dec 30, 2008 | 06:42 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Let's do something silly first:
Turn off all power to the sky box and TV.
Unplug all connections and reseat.
Plug it all back in.
Leave the box in standby mode for 1 minute to allow it to sort itself out, then turn on.
If this works you'll get channel 998.
If it doesn't then we'll try something else
Old Dec 30, 2008 | 06:46 PM
SHANE159's Avatar
SHANE159
Mines is still doin it:
Old Dec 30, 2008 | 07:02 PM
Rick Astley
I'm going now so if the above doesn't work do this:
1) Press services button.
2 Option 4 System Setup.
3) Then type 01 on your remote and press select.
4) If you at the right screen you'll see LNB setup so click on there.
5) Again if your at the right screen you'll see LNB power supply & 22khz Command, using your remote turn these both off.
5a) Click on save new settings.
6) Once you've done that and they are off press the red button on your remote to reset all settings.
7) The LNB and 22khz command should be back to on now... So click on where it says save new settings.
8) Press the Sky button on the remote and return to viewing, you should notice a small improvement immediately but give it some time to allow all the listings to refresh.
HTH
Tim
Old Dec 30, 2008 | 07:06 PM
slim20012's Avatar
slim20012
no channel 998 just blu background with blu box on screen say searching for listings
with box under it with date n time and further schedule info not avaiable
Old Dec 30, 2008 | 07:31 PM
slim20012's Avatar
slim20012
HTH
Tim
right done all that as well still no difference
LHD220Turbo
Oct 18, 2010 09:58 AM
mcst
Jan 23, 2009 08:58 AM
smudge_lad
24
Dec 13, 2007 12:59 AM
smudge_lad
41
Nov 8, 2007 06:08 PM
Zetec Andy
47
Nov 14, 2005 05:14 PM
