Fitting time on a Focus mk1 1.4 zetec clutch?
Just wondering if anyone knows the fitting time for a clutch on a mk1 focus 1.4 zetec? Put a coilpack on one the day but looks like its needing a clutch aswell. What sort of job is it to fit one?
not sure on official time but on a ramp can do it in a couple of hours no prob
easy enough nuffin to hard realy mate
make sure you replace the slave cylinder at the same time mate
if u renew the clutch slave cyl and its an early mk1 focus u will need to fit a modified clutch slave cyl pipe from the master cyl to the slave cyl as they changed the size of fittings on the slave cyl and they dont fit the old pipes!
plus change the pipe with the box out other wise u will be there for hours
used to do a clutch on them in about hour and half when i worked for fords plus an extra half hour for the pipe!
some manuals say about dropping the subframe but u dont need to there is loads of room to get the box out!
vdun01
Ford Fiesta
05-10-2017 08:14 AM
track.focus'd
12-08-2015 05:53 PM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
