2 Stroke oil in a diesel ???
got an email today with the following , just wondered what peoples thoughts were or is it a scam from a manufactures to sell 2 stroke oil ?
To all interested:
due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negativ impacts on the long-term stability of the injectors and the high pressure pump. The pump manufacturers have tried to react by lining the moving parts of the pumps with teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphor contained) diesel.
The engine-research centre of a well known German car manufacurer has conducted some long term tests of diesel additives to find out whether any one of them will have an impact on the long term reliability of the diesel engine components. This introduction to explain were my information comes from.
The results of this research: any diesel additive of any manufacturer presently on the market is not worth the money! BUT: 2-stroke oil, which we use in our motor saws, lawn mower or in 2-stroke motor engines has shown to have an extreme positive impact on diesel engines, if such 2-stroke oil is added to the diesel in a homoeophatic dosis of 1:200. In practical terms: 0,300 litre of 2-stroke oil into the 70l diesel tank. The 2-stroke oil will be absorbed by the diesel (emulsion) and grease every moving part of the high pressure pump and the injectors.
Besides this, the 2-stroke oil will keep the diesel engine clean, as it burnes cleaner as the diesel itself.
In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clogg, and the "burn free" process of the DPF will be much less.
One more information: in Germany we have to present our cars every 2 years to the TUV -Technical Supervision Organisation - who will check, amongs others, the pollution of petrol and diesel engines.
The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.
Besides this, the use of 2-stroke oil in the diesel will increase the milage by 3-5%.
To all interested:
yea Dave can't sleep all excited for Christmas lol, should go to bed as Ive got 2 fookin clutches to do the morra !
It would make sence I suppose... Thats why you DONT run sunflower oil in Modern Deisels...
CassyR... it smells fukkin ACE!!! We used to run it in our 4 strokes.
Been done for years, the research was no doubt done by KHD, this problem has been known for years as well, our government is well aware of it.
You can also use castor oil, or KLOTZ TECHNIPLATE, this has been running in a 250,000+ mile engine in a range rover that is running on 37p a litre heating oil, and has done since new, 95% smoke free even when cold starting.
To all interested:
To all interested:
2 stoke oil burns cleanly ???
Since when?! I burns blue which is incomplete combustion!
deathrider666
28-09-2015 06:12 PM
