Lights help
Old Dec 15, 2008 | 05:14 PM
smerth54's Avatar
smerth54
Default Lights help
Right when i turn my light on they dont work but if i put them on side lights the work slightly but are very dim, the main beam works but as soon as i turn the light on only the side light work? any ideas?
thanks rich
Old Dec 15, 2008 | 05:15 PM
mechanic28's Avatar
mechanic28
fuse box!if it the car in your avaitor
Old Dec 15, 2008 | 05:33 PM
Bad earth, clean them all up, run a temp earth straight to the bulbholder to verify.
Old Dec 15, 2008 | 05:55 PM
smerth54's Avatar
smerth54
y if its the car in the avaitor? and it is?
Old Dec 15, 2008 | 05:58 PM
mechanic28's Avatar
mechanic28
escorts and fiestas are known for fox box problems using causing the lights to play up!although it tends to effect the heater fan more in the fiestas!more then likely a crap earth!i would check the fuse box for any melted signs around the relays/fuses!
Old Dec 15, 2008 | 06:02 PM
smerth54's Avatar
smerth54
yea the fuel pump ones melted but ive found a new fuse board on the internet are they easy to fit tho?
http://cgi.ebay.co.uk/NEW-GENUINE-FO...3A1|240%3A1318
Old Dec 15, 2008 | 06:05 PM
smerth54's Avatar
smerth54
i have just had a fuel pump fitted so maybe the mechanic's moved on of the earths
Old Dec 15, 2008 | 06:11 PM
mechanic28's Avatar
mechanic28
not a mega easy job!but not a major job for a car electrican!might be worth getting it checked out first
Old Dec 15, 2008 | 06:17 PM
smerth54's Avatar
smerth54
oki then thanks m8
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
