Graph before it was mapped
Old Dec 11, 2008 | 09:21 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Default Graph before it was mapped
Just found this from a year ago tomorrow before my engine was mapped.
At the Flywheel
At the wheels
Old Dec 11, 2008 | 09:25 AM
Lo@der's Avatar
Lo@der
Don't know whether to go back to the same place for a power run now its live mapped, As going back there would be a good comparison of before and after?
Not sure though as I thought it was supposed to be run in 4th.
Old Dec 11, 2008 | 09:29 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes, I would go back there.
Proper dyno dynamics setup, so should be fairly repeatable.
Technically I beleive the equation they use for the temperature correction was probably slightly out of bounds at 8/9 degrees as I beleive its not designed for use below 15 degrees (thats how the DIN standards tend to work anyway, based on 15-35 degree inlet temps), but we are only talking about tiny inaccuracies from that, and realistically its probably going to be the same sort of temps at the moment anyway.
Go for it
And when you do, ask for a full set of printouts, they should do you one with boost, one with afr, etc
Old Dec 11, 2008 | 09:37 AM
GaryEvo's Avatar
GaryEvo
they can certianly repeat runs, heres 2 of mine over a month between...
Old Dec 11, 2008 | 09:44 AM
Lo@der's Avatar
Lo@der
It will be over a year between the two though?
Old Dec 11, 2008 | 09:46 AM
Luca's Avatar
Luca
Lukesville
You off today mate ?
Hows the Db sounding
Old Dec 11, 2008 | 09:56 AM
Lo@der's Avatar
Lo@der
Dunno, I cant do it on my own
Old Dec 11, 2008 | 09:57 AM
Chip's Avatar
Chip
Makes no difference, should still be very comparable on the DD setup, thats the whole point of them!
Old Dec 11, 2008 | 09:59 AM
Luca's Avatar
Luca
Lukesville
Good point mate, sorry manflu took over
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
